GMS/Diablo users within...
Old 10-27-2003, 02:06 PM
It's not mine! woo hoo!
demonspeed's Avatar
Default GMS/Diablo users within...
I have the Granatelli Diablo Predator and I really don't think it did anything. It said it would disable CAGS and whatnot, but nothing happened. Any tips on the best way to use this thing?
Old 10-28-2003, 04:11 PM
Mac 2002 SS's Avatar
well you can try to re-install the tuning first. remember while using your predator.....have your parking brake up your doors closed and your radio turned off. i know it may sound crazy ,but i'm sure diablo sport get alot of crazy calls when it's something that simple can throw everything out of wack. plug the predator in and go from there. i assume your car is a m6 by looking at your et and mph in your sig. remember ,always go to install tuning first. after that ,then you can go to modify parameters and install all the options you want and let it download in your car and you should see some pretty good results. i hope this helps you out a little bit. take care
Old 10-28-2003, 04:26 PM
Moderator
jimmyblue's Avatar
CAGS disable doesn't work for everyone, I've seen some
people complaining about this and they had to send the
unit back to DiabloSport for this to be fixed (basically the
custom tune drill). This being the case, I'd suggest trying
out the unit (performance tune & user adjusts) and see
if there's anything else you want to have them do by
way of custom tuning at the same time. No mod list
shown, so no suggestions offhand....
