Rattling sound coming from exhaust
Old 04-15-2009, 10:54 PM
alw041's Avatar
Default Rattling sound coming from exhaust
I have a rattling sound coming from my exhaust when I first start my car. It only last the first 10-30 seconds or so, and mostly does it when idling.
Anyone have any idea what this is? Hole in exhaust, broken cat or muffler?
Old 04-15-2009, 10:56 PM
Vicinity's Avatar
It's probably lose. That's why mine rattles.
Old 04-15-2009, 11:01 PM
alw041's Avatar
The sound has just recently started. Any idea what would be loose? I haven't had time to get under the car and check it out, but I wanted some insight before I start looking around.
Old 04-16-2009, 10:17 AM
D_Rock's Avatar
I had the same thing happen to my car turned out that one of the cats went bad. I guess the material inside came loose and it sounded like loose scrap metal banging around in th cats. Check that out, if you dont have cats then I dont know what to tell you.
Old 04-16-2009, 01:16 PM
coocooknu's Avatar
I hear its a common thing with Y pipes in our cars when they are cold. I assume it goes away after i warms up? Search for banging y pipe, or something like that, may help. I think they make a bracket you can mount up if its that annoying.
Old 04-16-2009, 03:37 PM
turbowhistle86's Avatar
the heat shield for the gas tank rubs the top of my Corsa muffler for about the first 20-30 seconds, after I put it in gear, it goes away.
Old 04-16-2009, 03:38 PM
D_Rock's Avatar
If its the y pipe then you might have to replace your motor mounts.
Old 04-16-2009, 08:02 PM
alw041's Avatar
I got under the car today to see if anything was loose, and I think it might be the muffler. I knocked on my muffler with my hand and on one of its sides I heard some metal rattling. Should I be hearing a loose metal sound inside the muffler when I tap on it? This was all while the car was turned off.
Also I can only hear it when I rev the engine a little, so I couldn't pinpoint it while the engine was on since I was by myself.
Old 04-16-2009, 09:19 PM
ShortChevy's Avatar
I've got that too, I'm fixing it with headers and true duals tomorrow lol, I'm tired of it. One of my cats rattle and the clamp for the catback/ I pipe connection. I've tightened it with an impact and a three foot rachet. It goes away and comes back. It only happens when I first start the car so that might be something to check for. Grab on the the cat back right by that clamp and wiggle/rock it and see if its loose.
