Choose my clutch....
If you guys were in the market for a new clutch kit, what clutch would you choose. I have a 2001 pontiac Trans am Ws6. the clutch is starting to feel like its going bad. So If anyone Can help it would be appreciated.
Location: Your girl's back door giving her the long stroke while you're at work
FYI I had the LS7 setup in my car and it never gave me a single problem. No more clutches for me though, I swapped to a TH350
Monster Clutch Level 3, great warranty, great customer service, great product!
Check out our website at www.monsterclutches.com or give me a call at the shop, 817-750-2000!
Will probably go with a monster clutch in the near future. I have heard they are excellent for someone at my power level.
But for a bolt-on car, you really should just save yourself some $$$ and go with a ls7 clutch. They can be had on the cheap if I remember correctly.
LS1Tech Premium Sponsor
What mods? If it's that low 11 second car, I'd run as quickly as possible away from the LS7 clutch and check out Monster! We offer them as well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Agreed as well...it seems that this is this almost flock mentality when it comes to using the LS2 clutch kit. And though I can understand the belief that better stock parts are a great way to go...there will always be some inherent limitations to these parts. The most obvious being the SAC type pressure-plate which can miss-adjust leading to release issues. SAC type pressure-plates also have less clamp-load than their non-SAC brethren. In the end, as great as an LS2 assembly may seem to be...they will always be less torque capable than a true built plate.
Very well said my friend!
