new TFS 205 heads
Old 04-16-2009, 07:25 AM
teke184's Avatar
Default new TFS 205 heads
anybody spot these in the new Summit catalog?
they list them for the 4.8/5.3/5.7L engines, max bore of 3.890 or something like that.
would be sweet to have that on a ls1 street motor....should make really good low and mid range.
price isn't bad either....$1900 i think
then again summit has had the Bigfoot Intake...sorry the Street Warrior...for sale for months...and it still hasn't seen the light of day.
Old 04-16-2009, 09:31 AM
9secondsflat's Avatar
they probably are the "as cast" version....personally i dont see a reason to use a 205 on a 346 when the 215's are perfect...you can control the power range from the cam one uses..
Old 04-16-2009, 12:52 PM
teke184's Avatar
its just something to look into.
while i agree the 215s are great, you might get a bit more power down low if you did the smaller runner.
perticularly with a smaller cam.
Old 04-16-2009, 01:59 PM
LilJayV10's Avatar
subscribing
Old 04-16-2009, 03:24 PM
QuickSilver's Avatar
They are not as cast they are a full CNC port.
I will be having a set of these along with the TFS stg 4 cam in about a month.
Looking to just make a good street driver.
Old 04-16-2009, 07:01 PM
EarlSS's Avatar
I wonder how they will compare to the AFR 205's.
Old 04-16-2009, 07:06 PM
litle88's Avatar
I have the as cast version from Vengeance for 1600.00 with the mods in my SIG and am very impressed!
AFR205's for over 2000.00 will be passed up by me!
Here is food for thought.... https://ls1tech.com/forums/dynamomet...-castings.html
Old 04-16-2009, 07:21 PM
allthrotle's Avatar
Trickflow is offering these heads in 3 different configurations...as cast, cnc'd chambers with as cast runners, and fully cnc'd. Fully cnc'd price will be $1995.95
Old 04-17-2009, 07:11 AM
teke184's Avatar
$1600 + $400 for roller rockers for the TFS heads.....same price as AFR.
still will be interested to see how these do.
Old 04-17-2009, 07:14 AM
Internet Mechanic
BlackScreaminMachine's Avatar
What I think people forget about is GM rockers do fail, and do have all the needle bearings fall out. Given with the cam profiles and valve train geometry, I can upgrade the rockers and get a kick *** head that virtually guarrentees 450 rwhp on a m6 car all day with a cam that is at least 22x/230+ Not bad.
Old 04-17-2009, 09:43 PM
litle88's Avatar
Speed has AFR's for 2200.00 http://www.speedinc.com/cont.cfm?cid=C0000164
I'm still 200.00 under. Now If Im gonna invest 2k on heads then why not get a good set of Rockers? Just my .o2!
Old 04-17-2009, 09:51 PM
The TFS 205's have Powdered metal guides, you dont have to run a roller rocker with them. Only the heads with bronze guids need the rollers.
Old 04-17-2009, 10:03 PM
Captain InsaneO's Avatar
subscribing
Same here.
Old 04-17-2009, 10:55 PM
moeZ28's Avatar
If the max bore is 3.890", they wont fit a 5.7L LS1 because the stock bore is 3.898"...HAHAHA!! Thought I'd bust some *****....
Old 04-18-2009, 08:39 AM
Chris05ssTruck's Avatar
With these heads u can use stock rockers guys....i have personally talked to Tooley about these heads and he expexts them to make more than the "as cast" heads on most set-ups.
Old 04-18-2009, 06:12 PM
LilJayV10's Avatar
Do you have a link to these heads?
Old 04-18-2009, 07:27 PM
AINT SKEERED's Avatar
this looks like a great head for the 5.3 truck guy's too. They would be good to have opened up some more also.
Old 04-18-2009, 09:28 PM
MelScrilla's Avatar
this is a good head setup for DD guys and guys that are looking for decent power at a good price. Racers will still go with the 215's, hey i dont have a problem with more options. Plus these heads cost about the same as cnc'd LS6 heads.
Old 04-19-2009, 05:29 AM
Tom@SpeedInc's Avatar
I've spoken with trick flow in regards to these heads a couple weeks ago, TFS 205 heads are fully CNC'd they will work with factory rocker arms by using powdered metal valve guides, like stock heads. They also use your factory valves.
so you pull your heads off, swap valves and springs over. I'm looking forward to reciving a set so can check valve drop and spring pockets etc.
Old 04-19-2009, 06:14 AM
SO you will need a valve job after?
Quick Reply: new TFS 205 heads
