powersteering resivor?
Old 04-16-2009, 02:29 PM
2002redhawk's Avatar
Default powersteering resivor?
Can i reuse it on a new pump? how do you remove it?
Old 04-16-2009, 03:29 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
What is this resivor you speak of?
Old 04-17-2009, 05:52 AM
LS1MCSS's Avatar
You need to pop off the metal clips holding it on and then just pull it off of the old pump. The clips have the center part bent down to keep them from coming off. Raise that part up and slide them to the side. It has an o-ring seal so make sure you don't cut the o-ring when you install it on the new pump.
