how can you tell the difference in the 4L80's?
there is a tag on the pass side, tells what year it is-i would avoid 91-93, they had an older arrangment of the force motor
97 up moved the cooler return line to the back into the center support
i forget what year they started using a bellhousing bolt in the 12 o clock postion
if you can, pick a 99 or newer, the more fact. upgrades the better, but all will work
looks like a 96-back trans, def not an 02-may have come out of an 02, but not orig-if you pull the pan and look at the force motor you can tell if its 91-93-if it was used in an 02, it might be a 94-96-the 94 up sup used a diff force motor voltage or whatever and and was not compatible with the older pcm
This is the case connector on the 60/65/70 with an ISS and the one on the 80 with the later harness should have one that looks very close. The only difference is a couple of pins are moved around. The early harness looks totally different and should have a threaded hole in the middle of it for a bolt. The unit you have is definitely a 91-96 and could be earlier unit with an updated harness. Here is a picture of the case connector. Vince
i thought about suggesting looking at the case plug, but if it was upgraded still wouldnt tell a lot-i have a 91-93 unit that was GM remanf., bought it on the chance it was 94-96 (they replace the side id plate with a diff one)
based on the case plug, but ended up being older w/upgraded harness
it was only $75, lol-it was a 4WD unit, but had the speed sen ring, i was gonna convert it to 2WD for a spare
thanks for the help guys this is really helpful, just for knowledge on here ( talked to GM yesterday but they weren't supposed to answer conversion questions) is there any problem or foreseen issues I would have with doing a LS1 conversion with the older model?
