change reluctor wheels
Old 04-17-2009, 01:02 AM
98TA6.0's Avatar
Default change reluctor wheels
i may have the 54 tooth reluctor on my LQ9 shortblock and my car uses the 24x. anyon have any ideas how to remove and install the wheel? also where can i get the replacement 24x?
Old 04-17-2009, 02:45 AM
InsaneDomestics's Avatar
Check out www.Lingenfelter.com They have a control module that converts the signal so you dont have to change the wheel. Its only a couple of hundred bucks so I would just go that route. Otherwise you would have to pull your Trans and Torque Converter which isnt fun (Trust Me) and it would just be a whole lot easier to buy the module.
Old 04-17-2009, 02:48 AM
Here is the actual link:
http://www.lingenfelter.com/mm5/merc...Category_Code=
Old 04-17-2009, 02:50 AM
LilJayV10's Avatar
Dammit,
Insane beat me to it. I was already to paste and BAM!!
Old 04-17-2009, 02:58 AM
ONEBAD383STROKER's Avatar
Beat me to it.
Old 04-17-2009, 04:01 AM
I had a feeling a couple of you guys would be tryin to post it up first so I was typing as fast as I could Lol
Old 04-17-2009, 05:40 AM
98TA6.0's Avatar
wow i see the transformer unit but i plan to replace the crank and cam position sensor with LS1 24X units. now i have the crank out of the 6.0 and am curious if it is possible to swap reluctor wheels. i can get my hands on a 24X reluctor fairly easy.
Old 04-17-2009, 05:58 AM
Phil'sC5vette's Avatar
that seems to easy.
how well does it work ?
Old 04-17-2009, 06:13 AM
If you already have the crank out then yeah I would just go ahead and swap reluctor wheels. That would save you a couple hundred bucks anyway. Where is the Cam Sensor located on the LQ9, Front or Back?
Originally Posted by Phil'sC5vette
that seems to easy.
How well does what work? The Module?
Old 04-17-2009, 06:49 AM
98TA6.0's Avatar
i believe it's on the rear next to the oil pressure switch. arent LS1s there as well?
Old 04-17-2009, 08:30 AM
BlackTA96's Avatar
Im pretty sure the LQ9 has a 24x.
Is there a way to tell a 54x from a 24x?
Quick Reply: change reluctor wheels
