98 z28 and hot wire fuel pump kit ??
i have a 98 z28 ss clone .. first f body 4th ls1 powerd car ..
im ready to upgrade to a 255lpg pump and was looking to get a hot wire kit for the pump .. but all im reading is it only works for 99+ ls1 with plastic fuel tanks !!
why is that ? u cant run a hot wire kit on a metal tank or am i missing sumthing ? i knw its a worth it mod and really wanna do it .. but how ??
if i cant run it ..
if i cant run it ..
wow thats more than i tought they cost .. price isnt bad tought ..
i had just seen alot of them in the 50-60 $ range on ebay // both kits do the same right or is the racetronics sumthing different ?
http://cgi.ebay.com/ebaymotors/1999-...Q5fAccessories
LS1TECH Sponsor
That price is for the custom fit pump, installation kit & the plug-n-play wiring harness.
If you built a $10 wiring harness, you didn't buy good parts. A good relay is nearly $20. You do not get these at Radio Shack. Remember this part is the one that leaves you stranded when it goes bad.
I also doubt you bought weatherpack connectors for everything.
You can go cheap, but this is what headaches are made of. Nothing like fixing the car whan you were planning to drive it...
The 98 wire harness is a different connector. I keep the harness in stock for the 98 cars. Not an easy install without the direct fit pump as Lonnie was mentioning.
Nate
Nate
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
We have s special jig which holds the pump in the correct position along with the filter sock, new upgraded in-tank harness, fuel tube etc.
Please read our web ad for details: http://www.racetronix.com/RX-F98-FPKG-2.html
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
We just dropped our price on these harnesses a while back. They are a good value considering how involved they are. The in-line mate is hand-made and sealed on the back end which is costly to do.
__________________
>WEB SITE<
>WEB SITE<
