Drag Racing Tech
Drilling Weld Prostars for 5/8" studs???
Old 04-17-2009, 04:18 PM
RENE'S RAGE's Avatar
Default Drilling Weld Prostars for 5/8" studs???
My prostar rims will not fit on my 5/8" wheel studs. They will go on the threaded part of the stud but will not slid over the bigger part of the stud,with no threads. What do I need to do? Can I drill the holes out bigger without messing up the finish on the rims or what? I had to drill out the rotors to 7/8" to fit over the studs. Need help on what to do.
Old 04-17-2009, 08:54 PM
xpndbl3's Avatar
if you had them on smaller studs and lugs with shanks before you probably pushed in a little amount of aluminum and made the hole slightly smaller. just hit them with a round hand file lightly and they should slip on.
Old 04-17-2009, 10:42 PM
TS6
TS6's Avatar
I hope you meant you drilled the rotors with a 5/8" bit, not 7/8".
Anyway, we just use a 5/8" drill bit to clean the holes up. Its tight.
Old 04-17-2009, 11:09 PM
DMH Fabrication's Avatar
Maybe your 5/8" studs are not installed straight or are off some? If they are not perfect you are not going to get the rims to slide over the shank part of the 5/8" studs.
Old 04-18-2009, 12:40 PM
These are brand new Moser axels, but still could be off alittle.
I have no problem with drilling out the rims just wandering what other people were doing to cure this problem.
Old 04-18-2009, 12:49 PM
No, rotors already had 5/8" holes. I drilled them out to 3/4" first but still wouldn't fit, then drilled them to 7/8" to make them fit. Rotors are no problem now. I think I'll start with a 5/8" bit and work my way up until rims fit .
Old 04-18-2009, 12:51 PM
Brand new rims. May just hit them with a hand file.
Old 04-18-2009, 01:01 PM
98 Silver Bullet's Avatar
a 5/8" wheel stud has a 11/16" shank
Old 04-18-2009, 01:07 PM
Can I drill out the rims without messing up the finish on them.
Old 04-18-2009, 04:01 PM
DanZ28's Avatar
File or one of those round tube sand paper wheels, hit them lightly. I would stay away from drill bits, as much should not be needed to get them on and they should not have slop in them once you do get them on. My billets were the same way..
Old 04-19-2009, 05:25 PM
I used a sand paper wheel on the holes on the back of the rims, opening them up alittle and then the rims slid right on. Thanks everyone.
Old 04-19-2009, 07:47 PM
DanZ28's Avatar
Good deal, glad it worked out..
Quick Reply: Drilling Weld Prostars for 5/8" studs???
