In middle of LS7 clutch swap, need help
Old 04-18-2009, 09:53 AM
UCABlackChevy's Avatar
Default In middle of LS7 clutch swap, need help
All right I got the trans off the bellhousing and the slave pulled out. I've read that the slave does not need to be shimmed for the LS7. When I took the slave off a big metal plate came out. My question is, is that a shim? I got a new slave from SDPC and it came with no such thing. I will try to get a picture of it shortly.
Also, I can't get the damn top bellhousing bolt out. I've got the socket on a universal and extension but it seems like there is not enough room for the socket and universal to get all the way on the bolt. I'm about to pull my hair out.
Old 04-18-2009, 10:12 AM
Picture of item in question.
Old 04-18-2009, 12:01 PM
blkbird's Avatar
Sure looks like a shim to me. Try pulling the back of the motor down a little to get more room.
Old 04-18-2009, 12:12 PM
CaliboyTA's Avatar
sure does look like a shim. when i put my ls7 clutch in i never used the shim. it worked fine.
Old 04-18-2009, 12:36 PM
So you (or any LS7 guys) don't remember having anything that looked like that on the slave when you did the install?
Old 04-18-2009, 12:41 PM
Justins00ss's Avatar
Nope no shim in my LS7 setup.
Old 04-18-2009, 01:09 PM
_JB_'s Avatar
No shim here.
Old 04-18-2009, 02:05 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I didn't use one either
Old 04-18-2009, 04:39 PM
TheLS1Kid's Avatar
I didn't use a shim. If you got a whole new kit with the clutch disc, pressure plate, and flywheel, just throw that shim in the trash. You wont need it.
Old 04-18-2009, 04:41 PM
blkbird's Avatar
You dont need a shim with the LS7. I didnt use one either.
Old 04-18-2009, 05:15 PM
I did my research before and read that I didn't need a shim I was just wondering whether that plate was a shim or a part of the slave.
Either way it doesn't matter much cause my friend decided to start the pilot bearing in and put it in backwards. So it'll probably be Tuesday before the dealership can get me another one. This has been a nightmare, I'm going out tonight and getting hammered.
If anyone is reading this and is on the fence of doing it yourself or paying someone else to do it. Check around and see how much it costs because if you can get away with it, have a shop do it for you.
Old 04-18-2009, 06:35 PM
bearcatt's Avatar
That looks like the shim Spec Clutches provides for thier stage 1.
Old 04-24-2009, 09:36 AM
All right, its almost all back together. I put in a new slave, does the clutch need bleeding? If so, I have a mity vac can I just jam the nozzle in the reservoir and give it some vacuum and hit the clutch a few times? Or is there anything special to bleeding a new slave?
Old 04-24-2009, 11:25 AM
I'm going home after lunch and if I don't hear anything before I get there, I'm just going to go with the jamming mity vac into reservoir, bleed, and hope thats all I need!
Old 04-24-2009, 09:12 PM
crainholio's Avatar
You'll want to use the plastic conical tip on the MityVac hose, no way you'll get a seal in the hole at the bottom of the reservoir w/o it.
Quick Reply: In middle of LS7 clutch swap, need help
