LS1Miata-need 04 GTO cooling fan relay pinouts
Old 04-19-2009, 07:46 AM
NRXEB18's Avatar
Default LS1Miata-need 04 GTO cooling fan relay pinouts
Got most of the wiring figured out, but the pinout chart for the 04 GTO only shows one connection (GREEN connector, #33, "High Speed Cooling Fan Relay Control"). I'm using two fans and would like to have them staged on temp. I'm new to the PCM world - any help is appreciated.
2004 GTO, LS1/T56, stock, w/PCM & harness going in 2000 Miata
-Ray
Old 04-19-2009, 08:24 AM
the_merv's Avatar
Is there 3 Relays with that setup from the Factory..as in do they have a low and high speed?
Old 04-19-2009, 09:09 AM
GA95DCMSS's Avatar
Its a pin thats not used from the factory in the 04 GTO PCM.
Blue Conn. Pin #42 : Low Speed cooling fan relay Control
Green Conn. Pin #33: High speed cooling fan relay.
I'm using a PCM from an 04 Yukon with a modified 04 GTO flash, and it is pretty much just hook and go. Works great.
You can wire them with 2 or 3 relays, but that's your choice. I'm actually looking at doing mine with a 3rd relay, even though my 2 are working fine.
Old 04-19-2009, 09:47 AM
NRXEB18's Avatar
Great stuff guys. Thanks for your help!
-Ray
Old 04-19-2009, 12:28 PM
the_merv's Avatar
The 3 Relay setup is very easy to wire in.
Old 08-01-2009, 11:28 PM
Ls1Mx-5's Avatar
How was the rest of the wiring?
Old 01-14-2010, 09:06 AM
patoruzrs73's Avatar
Default more info
I have the same problem mentioned above, but let me see if I understand what you´re suggesting, you are saying that i can use the Blue 42 pin and the 2 realy configuration and it will work? I´m also using a 04 gto pcm.
Regards
Old 01-14-2010, 12:52 PM
the_merv's Avatar
You can wire it with 2 Relays..but it's going to be to where it's one Fan on high..then when the 2nd one kicks on it's going to be high speed also. There will be no low speed.
Old 01-15-2010, 02:38 PM
.. ok maybe a scheme will explain better? please?
Old 01-15-2010, 04:54 PM
LS1MCSS's Avatar
For high and low speed you need three relays. Here is a chematic for an f-body. You would just need to use the correct high and low signals instead of how they are listed here. I believe that same schematic is in the fac's somewhere with the relay pin numbers marked on it.
Attached Thumbnails LS1Miata-need 04 GTO cooling fan relay pinouts-cooling-fans.gif
Old 01-15-2010, 05:52 PM
ok great info, but the only difference is that the low fan speed signal is not from the PCM on the GTO PCM, any way thanks for the diagram. Anyone else thay may help?..What alternative do I have? Control de fans not with the PCM?
Old 01-15-2010, 10:55 PM
the_merv's Avatar
The PCM doesn't control the Low Fan setting?
Old 01-15-2010, 11:20 PM
the PCM pin 42 is not used... not cable..
on the gto de BCM (body control module) controls de low speed fan.., any alternative method to thw low speed fan?
Old 01-16-2010, 05:14 PM
downset71's Avatar
use a stand-alone setup with a radiator probe for the smaller fan(on high)then run a relay for @2nd fan(also on high) when the a/c comes on. i have the GTO fans, thats what i did. i didnt bother to use the 2 low settings
Old 01-16-2010, 05:54 PM
the_merv's Avatar
That's gay that the BCM Controls it.. is there a wire coming out of that Pin #42?
The reason I ask is something has to tell the BCM to turn it on at low setting..unless it goes off of the Temp and does it itself.
Try running a wire off of that #42 if there is nothing there and see what it does..
Old 06-16-2010, 05:11 AM
mklinger's Avatar
Default Pin #42
Has anyone confirmed that pin#42 will trigger the low spped fan relay?
Thanks
Old 06-16-2010, 11:14 AM
RHDV8's Avatar
I have pin 42 off of the blue connector working as a fan turn on. From what I understand this has to be enabled in the tune. As it's done in the tune you can set either of the turn on signals to any temp you like so either can be low temp or high temp. Obviously you need to add a pin in that connector as it's normally unused in the gto.
Old 06-16-2010, 01:21 PM
mklinger's Avatar
Default Pin #42 and Dual Fan Wiring
In regards to Blue Pin #42, here is a great little tech article on the subject. Very informative.
Dual Fan Wiring Harness
Old 06-16-2010, 03:13 PM
GA95DCMSS's Avatar
As RHDV8 said, I can confirm that Blue #42 WILL WORK. That is how I have mine wired up, and it's been working for 2 years that way. You just have to make sure you go in and set the Fans setting to 2 fans under "System" in HPTuners.
Old 07-07-2010, 04:08 PM
LS88FoxBody's Avatar
Will this work in this application?
https://ls1tech.com/forums/conversio...l#post13568906
Quick Reply: LS1Miata-need 04 GTO cooling fan relay pinouts
