Newbie moving up to LS1Edit. Remove HPP3 first?
Newbie here...Moving from HPP3 "performance tune" (whatever that is...) on to Ls1Edit. Should HPP3 tune be removed back to stock first?
Thanks. Great board!!!!!
What you should do is to do a read using LS1Edit with the Hpp3 tune still installed. Then remove the Hpp3 and sell it. Now do a stock read using LS1Edit. This way you can look to see what HPP3 did and if it made your car better, you can upload that HPP3 tune using ls1edit.
That is what I did.
