engine vin #
dont think so?
just trying to get my rock buggy green stickered and california wont even think about giving it to me until they run the vin on the motor...
every person ive talked to says its on the black of the block but i cantfind it
Location: Your girl's back door giving her the long stroke while you're at work
It's just above the bellhousing, the holes are just a reference point on where they are on the block.
Here is a shitty pic
Sorry I misread the question
The part number is only going to tell what year the block is from, if it even breaks it down that far.
There is a the last 8 of the vin etched on the left rear of the block under the
head, you need amirror and a flashlight to see if its on the car, i work at a dealer trust me its there its hard to make it out but if you do post it and i can run a gm VIS and see what year it came from
the motor is out of a 99 camaro, the chp needs it to run a vin check to see if it is stolen before i can register my rock buggy for off road. the chp told me it was on the back of the motor i couldnt find it. i will look closer in that area.
ramair racer can you pull any more info out of that number?
