Oil leaking BAD after manifold swap.
Well I just finished my intake manifold swap and I busted my oil pressure sending unit and replaced it. But as I had no socket to fit it, I screwed it in as tight as I could with my hand.
I used all new gaskets on my intake manifold but I noticed today I have a FEROCIOUS oil leak dripping where the engine meets the transmission. I reached back and rubbed my finger all over the new oil pressure sending unit and found NO oil. Just dirt. Are there ANY ideas you guys have that I could check for?! I'm extremely scared to drive. But I keep checking my dipstick and my oil level is actually pretty good. Like nothing abnormal there.
Also, my PCV valve dry-rotted so I had to replace with a straight piece of rubber hose.
When I put on my LS6 intake, I sanded down the entire bottom of the manifold so I didn't have to buy new coolant lines.
If you need to know anything else PLEASE ask!
The quicker the better!
Help is greatly appreciated.
When I got the sending unit, it had some white junk on it. Looked like liquid teflon tape. Or white out.
But I just reached back there and rubbed my finger ALL over the bottom of the sending unit and all I get is dirt.
BUT! The block is still insanely hot (yeah I burn myself each time I check) so could the oil evaporate before I have time to check?
The 'dirt' I find is very fine, like the kind I found in both my manifolds. (Both were used)
Like the little that comes from the PCV valve!
OK another update.
I went out and found out it only leaks when running.
He is a picture of the newspaper I had under it.
The 'fresh' looking oil is what came out from running about 7 minutes with a little bit of revving.
But the total was over a 2 hour period...
Really worried
Really worried
If nothing else was changed, its got to be the sending unit, id top it off, let it run a few minutes until it started to drip, then remove the intake manifold and check, shouldnt take that long.
^^ Or you can do that, a lot quicker
If you did not do anything else then it has to be the sending unit. You must be missing something. Like someone said earlier, 50-60 psi for the oil system, hand tight won't cut it. I'd pull the intake and tighten that thing down.
