remove salt
remove salt
What should I use to remove heavy salt oxidation on a 2005 aluminum block?
Can I give it a good scrub with de-greaser and paint over it or do I need to take a wire brush and get everything off before throwing on some aluminum colored engine enamel. If I need to remove all signs of the oxidation can you recommend a product.
Thanx in advance.
Thanx in advance.
