LS4 Performance - 5x114.3 and 5x115....come inside.
View Full Version : 5x114.3 and 5x115....come inside.
Nacho SS
04-20-2009, 12:52 AM
Now I've done my reading on this issue...some suggest thats it will be alright overall, other freak out and tell you your car is going to rattle into a pile of parts. Now 5x114.3 opens a much wider selection of wheels (mostly mustang fitaments) and I don't care for the super hood looking rims that belong on donks when you look up 5x115 on most wheel searches. I want something that speaks of performance and muscle. So if I branch out into mustang wheels for the look I want what are the potential devils I'm playing with here...realistically.
(FWIW hubcentric rings and new wheels studs are a must)
neilownz
04-20-2009, 01:27 AM
*freaks out*
What size and style were you looking for?
ZyroXZ2
04-20-2009, 01:40 AM
The bolt pattern only really makes a difference if you drive hard or do any sort of performance driving. Drag racing counts as well. If you daily drive on a slightly incorrect bolt pattern, you'll probably get away with it. If you autocross or go to the drag strip often... well good luck!!! However, as long as you have a proper hubcentric ring fitted, you have nothing to worry about.
neilownz
04-20-2009, 01:41 AM
Looking for a 4.5" to 115mm 5 lug adapter. That's what you need if anyone make it...
http://cgi.ebay.com/ebaymotors/4-Billet-wheel-adapter-5-lug-5x115mm-to-5x115_W0QQcmdZViewItemQQcategoryZ33749QQihZ002QQit emZ120387541346QQtcZphoto
Backspace will be off though.
Mels SS
04-20-2009, 07:01 AM
A lot of guys at Club Gp use the 5X114 on there Grand Prix.
beznich
04-20-2009, 09:16 AM
Maybe you can see if another car has the same hub specs with the bolt pattern you are looking for.
If you can find another car that has different hubs with the bolt pattern you are looking for you can swap them out, swap out the rotors, and be good to go.
RickAKATed10
04-20-2009, 12:39 PM
I'm on 5x114.3 wheels. They're fine. No hub centric rings were needed, and don't experience any vibrations when driving. I had everything mounted and balanced at Discount Tire Direct in Highland, IN.
dj_stylzpgh/GXP05
04-20-2009, 02:17 PM
5x114.3 work I've had no probs
mike690003
04-20-2009, 03:20 PM
with a 35-38 offset... ;)
and the 114.3 will work
eddiemoney
04-20-2009, 04:29 PM
114.3 will work, but I have seen cars torqued real hard (Burnouts, drag racing, etc) shear the bolts off in ways consistent with the rubbing that could be associated with being just a shade off.
neilownz
04-21-2009, 01:08 AM
Just change them to arps and rip the center out of the wheel instead.
The Guz
04-21-2009, 05:24 PM
I run the 5x114.3 bolt pattern with a +35 offset on my 99 grand prix that I daily drive. Been on the car for almost 2 years now with no problems. I use hub rings with mine.
