No Oil Pressure on Start Up
I just finished putting my engine back together and ran into a problem with no oil pressure.
I installed heads, new Comp cam, new Comp timing chain, Comp lifters, and TSP ported LS6 oil pump. I started the car and shut it down after approx. 3 sec due to no pressure. I verified all wiring to both my factory and Auto Meter pillar gauge, then restarted and shut it back down after about 3 sec., still no oil Pressure; motor is was not producing any noise, all sounded smooth. I removed the driver’s side valve cover and saw there was no oil getting up there.
This was my first time working on an LS motor, but I am fairly mechanically inclined and don’t think I could have installed the pump wrong…doesn’t seem like you really can install it wrong. Could it just be a bad pump?! Are there any newbie mistakes anyone can think of that can lead to this? I very well could have made a stupid mistake.
I was so unsure about that o-ring when I was installing it, that I actually removed the pick up tube like 5 times to make sure I had it in ther right...but that is not to say I may have screwed it up on the 5th time.
You motor is probably ok - I would try it again. Two 3-seconds shots may not be enough to see oil pressure. Time is relative and those are some of the longest seconds.
I wasn't sure if it was long enough, but I didn't want to risk running it any longer. I thought for sure after the 2nd time I should see something. Car was idling somewhere around 1500 rpm's, so I assumed I that would have been more reason to see pressure quickly. The car has been sitting for about 6 months now, so it is probably pretty dry in there, don't want to ruin a bearing.
Before you tear down your engine and check the o ring, I suggest you overfill the crank with cheap 5w30 oil. Before doing so pull the plug on the driver side lower front which is just past the oil pump. It took 19 qts for mine to flow out this hole but I have a modied pan and it only holds 5.5 qts when full. I pulled my engine out 3 times, installed 3 new oil rings, double bolted the pickup tube, added rtv and still no pressure. Turns out the problem was the pump was dry and would not prime it self. Once I got oil in the pump it has worked every sense. There are other ways to prime it but I think you need a special kit. Turn the engine over without starting it. Once you see pressure drain out the oil and fill it to normal level and start the engine. It worked for me, might save you time and a headache pulling the engine and dropping the pan.
I have heard of that happening but never experienced it. Did you lube up the inside of the pump before you closed it back up?
No my engine was used with 38k and had been sitting for years before I installed it. I purchased the modied oil pan and tube from S&P and called them when the problem occured. They said they had seen this probelm before and told me to stuff vasoline in the pump and reinstall the pickup tube and o-ring. I did that and it still did not prime. I was about to stick a gun to my head when I told myself screw it. If it is the o ring I will know for sure if I over fill it past the ring and put oil in the pump itself. And common sense told me if it did not work then I had a bad pump or other problem and not a o ring problem.
Unplug your wiring harness on each side of the valve covers where the coil pack harness plugs in and turn the engine over for a few seconds until you build oil pressure. It will take a few tense seconds for the pump to push oil to the top of the motor where the oil pressure sensor is. Once you have pressure, plug the coil pack harness back in and fire the engine.
well when we did my buddys car it took about 10 sec for oil to build up i think ur fine just not letting it run long enough on his we also did H/C/I and 10296 pump and after it ran for a bit it had oil pressure instantly everytime it started
how much assembly lube did you use? Unplug your coil packs and pull your plugs out so there is no pressure on the bearings when you turn the motor over (this is a must). Hook up a battery charger and let the motor turn over with no plugs and fuel pump fuse pulled. When I primed my fresh motor this way it built up ~35-40 psi. Took about 15-20 seconds
All is good! Thanks for all your input, much appreciated.
I went ahead and pulled the plugs, coil pack connectors, and injector connectors (started smelling pretty rich after cranking it a bit), then turned the motor. Took about 3-4 times of cranking it for about 10 seconds to see the pressure. I pulled the driver's side valve cover to ensure oil was up there, and all was good. Put it all back together and started it up, sounds good and oil pressure is fine.
And here I was ready to come home from work today and start pulling off the pump...
LSxGuy widda 9sec Mustang
What is your pressure now that you have it? That O-ring causes quite a scare sometimes, good to see yours seemed to seal up fine. I use a generous coating of assembly lube on both the o-ring and the pump inlet to help avoid pinching or cutting the o-ring. I've had several customers have self-install issues that I had to go back into and fix, when it was just the o-ring.
FWIW the TSP pumps come ready-to-install and pre-lubed to assist getting oil pressure quicker, many other brands come dry and need either oil or some liquid assembly lube on the gears to alleviate priming issues.
I am having this same problem. My motor runs for about 3 seconds or so then dies. The motor has been sitting for about a year and a half. I have started it for 3 seconds a lot though like 10 times to check different things I thought were the problem. I am now afraid to try and turn it over. Should I try over filling it with oil like the one guy suggested. Where is the plug he is talking about too? Please help.
