Western Members CA, AZ, NV, UT, CO, NM, HI
Link for passenger window fix?
Old 04-20-2009, 01:25 PM
DobsZ28's Avatar
Default Link for passenger window fix?
I saw a while ago that there was a new bypass product apparently that fixed the problem of the passenger window losing all of it's power by doing some sort of bypass...
Anyone have the link for it? I've tried finding it but can't, and second..
Anyone know how to do it? I have no clue..any help would be appreciated, i have 5% tints with t-tops, and i can't take the tops off while leaving one completely black window up...looks ridiculous.
Old 04-20-2009, 01:43 PM
ss.slp.ls1's Avatar
That fix is to boost the power to the electric motor, because from the factory it is underpowered. But it does not fix a bad motor. If your window is ridiculously slow or doesn't move at all, you need a new motor and that kit won't help you.
http://www.ws6project.com/user_stor/...oducts_id=2055
Old 04-20-2009, 01:46 PM
DobsZ28's Avatar
Is the kit pretty easy to install? I figured I had to buy a new window motor anyways, but, heard that this thing helps with the speed tremendously
Old 04-20-2009, 01:48 PM
ss.slp.ls1's Avatar
Haven't installed it before, but I'm sure it comes with instructions and if you are moderately competent with electronics, it should be a piece of cake.
Old 04-20-2009, 02:02 PM
TireSm0ke's Avatar
It does make the window alot faster, and its not that tough to install. But then again its not all that hard to make yourself either....
Old 04-20-2009, 03:57 PM
brandotron's Avatar
It took me about an hour and four beers to install.
Old 04-20-2009, 04:45 PM
Banned Village Idiot
LS1BLKSS's Avatar
if anyone needs a motor, i have a brand new motor that never got to use it, my driver side motor fucked up on me and it was cheaper to buy the set i only used one motor, these motors are for either driver or pass side... $20 picked up!!!!!
Old 04-20-2009, 04:48 PM
ss.slp.ls1's Avatar
dibs.
Old 04-20-2009, 04:54 PM
LS1BLKSS's Avatar
^^^ very nice come pick it up at my pad tonite
Old 04-20-2009, 07:24 PM
lowerthanyou00's Avatar
isnt that just running a straight lead from the battery to the relay? sounds a lil id just pop in a new regulator, its not losing power its just not getting enough to start with which eventually destroys the motor damned chevahs
Old 04-20-2009, 10:05 PM
Datzneat's Avatar
I actually really need that motor. Let me at it SRJ.
Old 04-21-2009, 08:37 AM
ss.slp.ls1's Avatar
Too late, it's already in my door.
Old 04-21-2009, 09:29 AM
Stroker396@APF's Avatar
The window motors can be found on flee bay for $20 and the guys who sell the wiring mod for some reason got banned from this site (don't ask me why) I think it is autotrix
Old 04-23-2009, 10:58 AM
brandotron's Avatar
They got banned? I wonder why--their customer service was awesome and they made a pretty decent product. Ah well, probably money.
Old 04-24-2009, 10:25 PM
TireSm0ke's Avatar
Like I said, that autotrix mod is something you can make if your ok at dealing with wiring. Made mine in about an hour, and that was without anything to go off of.
Old 04-25-2009, 08:01 AM
oldNslow89TA's Avatar
tiresmoke, how can i make one like that? have spools of wire at work and any connectors, what relays would be needed?
Old 04-25-2009, 05:30 PM
TireSm0ke's Avatar
You need some wire, preferably 12awg, 2 4-pin relays, 8 female spade connectors (12awg), and either some crimp connectors are a soldering iron depending on which way you want your connectors sealed. PM me for wiring details.
12)
Quick Reply: Link for passenger window fix?
