No second gear
Old 04-20-2009, 02:15 PM
snksknr's Avatar
Default No second gear
Stock 4l60e with 80,xxx miles, no second gear. Scanner showed a p0752 code, which is the 1-2 shift solinoid. I changed the solinoid and still no second gear. Does anyone have any idea what else it could be?
Old 04-20-2009, 03:02 PM
LS1Tech Sponsor
performabuilt's Avatar
Do you have 4th gear ? if not I would suspect and 2-4 band failure
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-23-2009, 01:22 PM
snksknr's Avatar
Yes, I still have 4th gear. The transmission was removed to replace a cracked flexplate. After everything was put back together it worked just fine, it wasnt until about 10-15 miles later that it started acting up. It felt like it was getting hung up between 1st and 2nd and after 2-3 seconds 2nd gear would finally engage. After I got home and parked the car for a while, I had to leave agian and this time there was no second gear at all.
Old 04-23-2009, 01:24 PM
LS1Tech Sponsor
I am assuming you have a stock converter also?
__________________
Call 888-744-6542
Old 04-24-2009, 02:01 PM
snksknr's Avatar
yes, everything is stock.
