General Maintenance & Repairs - electrical issue during high RPM shifting
landonew
04-20-2009, 05:39 PM
When I shift at high RPMs or do a hard launch, the guages flicker and then go all the way to the right (like when you start the car.
It appears to be losing power during hard shifts or other violent movements.
I am assuming that it is a loose ground. I am not sure where all the grounds are though, so which ones should I check?
Thanks
haacer
04-20-2009, 10:17 PM
Thanks
That's where I would start as well. Try to move your battery terminal connections with your hand. If they move at all you need to tighten them. From there you'd have to start looking at body grounds. Check the battery first, if that's not it I can provide locations. PM me for this.
landonew
04-21-2009, 12:41 AM
PM sent.
The battery was the first place I checked.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
