Which cams are considered the donkey dick cams?
Old 04-20-2009, 11:55 PM
1SLwLS1's Avatar
Default Which cams are considered the donkey dick cams?
From what I know, its the MS4, Trex, and Polluter. I know there are more out there. Just curious if anyone wants to add to the list of the donkeys? Also please add specs if you know them
Old 04-21-2009, 12:56 AM
ramdaspadhye's Avatar
lmao @ that
Old 04-21-2009, 01:44 AM
Joshiedoom's Avatar
In the famous words on one of the mods..
ms3=gods *****
Old 04-21-2009, 07:55 AM
Chrome355z's Avatar
ms3=gods *****
And it's got one hell of a premature ejaculation problem.
(no midrange)
Old 04-21-2009, 09:28 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We've engine dyno tested all of the cams mentioned in the thread so far (and more), back to back to ensure a level playing field. I can tell you that the results are interesting on many levels. When one company advertises that they "donkey dick" camshaft makes much better bottom end and mid-range power than everyone else's, beware. They are all big and aggressive camshafts designed to make peak power. If you want perfect driveability, terrific bottom end and mid-range power, get a smaller camshaft. There's only so many lobes out there to tweak the VE's to work in your favor, and at the end of the day a 240º+ intake duration camshaft simply does not drive under 3000rpm like a sub 230º intake duration cam
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-21-2009, 06:34 PM
1SLwLS1's Avatar
I plan on the MS4, just trying to get a read on everything else
Old 04-21-2009, 08:27 PM
fatdave's Avatar
Love my MS4. Just have to have all of the supporting mods to get the most out of it.
Old 04-21-2009, 08:37 PM
1SLwLS1's Avatar
do you have those supporting mods or no?
Old 04-21-2009, 09:59 PM
SweetS10V8's Avatar
Anything mid 230s is going to give up driveability and torque in most cases.
Just my story(Quickly), Ive got a 6.0L, CNC LS3 Lingenfelter heads, 1 3/4" Longtubes, mandrel exhaust, etc, etc, and Im going with a 219/235 .607/.621 114 cam. Over camming an engine sucks, and its sucks forever until you change it. If your deciding between two levels of cams, error smaller.
Old 04-21-2009, 10:21 PM
s1ck s0n's Avatar
i <3 my t-rex
Old 04-22-2009, 07:10 AM
Zac_Speed's Avatar
I love my cam alot. 220/230 .585/.585 112lsa
Even though my tune isn't were I think it should be it still has all that grunt down low like a stocker would. Once I get all my new parts on Saturday, Dlove and I are going to get it tuned. Hopefully I'll go from 400rwhp to something like 430-440 so...
Old 04-22-2009, 11:54 AM
Honda Nick's Avatar
MS4 + PRC 215 heads + gears = happiness
Old 04-22-2009, 06:58 PM
fatdave's Avatar
Yes I do.
Fully ported 241 heads, ARH long tubes fast 90/nw90 4.10's ect ect ect
Quick Reply: Which cams are considered the donkey dick cams?
