The Firechicken Project
Well the build is almost finished.
355
stock crank
studded mains
forged eagle 6 inch rods
forged flat top weisco pistons
11.7 to 1 compression
head studs
LE2 h/c/i (23x/24x, 53x/54x, 110 lsa)
1.6 pro mag rockers
36lb svo injectors
58mm bbk tb
all accessories deleted
electric water pump
pacesetters lt's
little red button
spec 3 clutch
ford 9 inch with spool
spohn torque arm, cross member with ds loop, adjustable lca, 1 inch sway bar, adjustable panhard bar.
I owe a huge thanks to Robert and Debbie at MIDWEST TRANSMISSION for all of there help on this project, couldn't have done it with out them. The goal is to have it dropped in this weekend. Heres a few pics
http://www.facebook.com/album.php?ai...9&l=d428bfd794
355
stock crank
studded mains
head studs
1.6 pro mag rockers
36lb svo injectors
58mm bbk tb
electric water pump
pacesetters lt's
little red button
spec 3 clutch
beautiful, now when you're done save up some money, get some custom made emblems of a rooster on fire and paint / put a decal of a rooster on fire on your hood, then its totally complete!
http://www.facebook.com/photo.php?pi...&id=1309620089
Well the motor is in the car now, with everything plugged in and what not but it wont start. You can here the soleniod clicking and the starter trying to move, but it won't turn over. Also tried jump starting it with no luck. Any ideas??
Updated pics
Updated pics
Yup, i got it figured out, and it was a ground wire. It finally fired tonight!! I was so glad to hear it finally run again. I think if i adjust the TB screw it might even wanna idle. I'm calling redline performance tomorrow in STL, to see if they can get me next week sometime to get it tuned. I hope to get the suspension setup tomorrow well enough so i can drive it a little to break it in.
Yeah you can try adjusting the screw but like me you'll need to adjust the TPS and IAC. I already adjusted the screw to help it idle but need to reset the TPS and check the IAC. I'm sure you're loving the way it sounds. I know I'm liking the way mine sounds. Sounds like a full blown race car.
Are you running it with the bigger injectors untuned? It would be a shame to have it done and then flow the cylinders with fuel.
Well i think its finally time for a update I had the car, street tuned finally. I think with a dyno tune i might be able to get a little more out of it. It put down 377hp/342tq. I'll try and get the graph up soon. I took it to the track last night, and ran 2 11.89 passes, one at 115.78 and the other at 116.02. The car has a miss to it. I think its a plug wire, because they're brand new plugs, I put them in yesterday hoping that would fix it. I'm gonna try and trouble shoot it some today and figure it out.
