suspension help
suspension help
I have a 99 f-body need help with gettin the sixty foot times down. The car makes 511rwh/605ftlbs it has qa1 12 way single adjustable shocks with coil overs in the front dbl adjustable bmr torque tub without relocation bracket tubler lower control arms moser 12 bolt 410 gears. the best the car has went is a 1.7 60 ft iam runnin the car on a BFG 325/50 15 drag radial and want to keep runnin the radial it is a stick car what should i set the
ie, pinion angle and shock settings
thanks
thanks
