347 afr heads????????????
ok fellas got a few questions on my build? my setup is a stock ls1 crank eagle rods diamond flat top pistons with 2cc valve releafs. this set up is 9 4 1 compression w a 72cc chamber head but im changing my set up to run a 2 stage kit. i would like my compression to be in the 11s. i think if i mill the afrs to 59cc it will be there with the 205 afr heads. if you know anything about a 347 set up please give advice. if anyone has any videos of any cars with this set up. just looking for advice before i spend the cash on the afrs
thanks
note please if you have any videos dyno or at thr track that would be nice.
thanks
That's because they're not... but anyway..
The AFR 205s should work great on your 347. Pat G put down 500rwhp in his car with Mamofied AFRs and a custom cam on his 347.
http://www.guerragroup.com/2000TA.htm
