BMR Suspension
04-21-2009, 05:22 PM
BMR Lowering Springs - On Sale Now!!!
20% OFF
Complete Set - 4th Gen F-Body (SP001) : $199.96 per set of 4
Tech Specs: Front Lowering Spring (SP002)
1.25" drop
Linear rate of 550 pounds per inch
The BMR spring is very streetable, but slightly aggressive.
Weight - Less than 16 pounds per set of 2
Powdercoated red
Made from high-tensile silicon chrome steel (same material used by most NASCAR teams)
BMR springs are Proudly Made In America
Tech Specs: Rear Lowering Spring (SP003)
1.25" drop
Working linear rate of 160 pounds per inch
The BMR spring has an i.d. of 2-9/16" on the bottom so it will fit properly on the rear axle spring perch (o.d. of 2.5").
Weight - Less than 12 pounds per set of 2
Powdercoated red
Sale ends on May 17th!!!
Order by clicking here or by calling BMR at (813) 986 9302:
http://www.gnetworks.com/v4/go.gnf?s...ult&d=products (http://www.gnetworks.com/v4/go.gnf?s=bmr&product=11678&n=default&d=products)
Springs can also be ordered through an authorized BMR Distributor: http://www.bmrfabrication.com/distributors.htm (http://www.bmrfabrication.com/distributors.htm)
20% OFF
1.25" drop
Powdercoated red
1.25" drop
Powdercoated red
