Paint & Body Work - Separating turn signal lens... bake or cut?
InsaneAuto86
04-22-2009, 04:51 PM
I need to separate the front camaro turn signal lens from the housing. I have two sets to play with. What is the best way, bake or a thin blade dremel?
I know a headlight you would bake, but the adhesive appears to be different on the turn signals.
Thanks, Matt
KLaBZ28
04-22-2009, 05:37 PM
what the hell you taking them apart for
InsaneAuto86
04-23-2009, 12:06 PM
Audi-inspired white LED strip running the length of the lens.
Any suggestions?
KLaBZ28
04-23-2009, 02:47 PM
Ohh nice that sounds interesting. I just took a look at my old factory amber lenses and I'd say either bake them or use a hot knife if you had one. Keeps us updated
InsaneAuto86
04-23-2009, 03:52 PM
Do you know what temp/time to bake? It looks like the lens are sealed with some sort of epoxy, which I dont think will bake to well.
KLaBZ28
04-23-2009, 04:59 PM
Agreed its not like a silicon sealer so thats why I'd say best bet is use a hitknife of something.
blindxeyed
04-24-2009, 12:51 AM
They're actually laminated together. The housing and the lens were heated up and then pressed together to allow the plastic to melt together forming a bond. The only real way to separate them is to use a dremel and cut off the outer lens. Afterwards I suppose you could use some silicone and press them back together.
InsaneAuto86
04-24-2009, 09:55 AM
Thanks guys! I will be working on this project this weekend so I'll let everyone know how it turns out!
InsaneAuto86
04-24-2009, 07:18 PM
Progress...
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting001.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting001.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting003.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting003.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting014.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting014.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting017.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting017.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting020.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting020.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting021.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting021.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_turnsignalcutting022.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=turnsignalcutting022.jpg)
joshprescotttttt5
04-26-2009, 09:19 PM
yea i have the same idea that you have, ive been wanting to get some clear corners for my t/a and put a white strip in them from seeing the audi's.
looks good so far, keep it up
InsaneAuto86
05-06-2009, 09:17 PM
Finished...
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals001.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals001.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals002.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals002.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals003.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals003.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals004.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals004.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals005.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals005.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals006.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals006.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals007.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals007.jpg)
http://i91.photobucket.com/albums/k311/Insaneauto86/th_LEDturnsignals008.jpg (http://s91.photobucket.com/albums/k311/Insaneauto86/?action=view¤t=LEDturnsignals008.jpg)
SparkyJJO
05-06-2009, 10:11 PM
Cool now mount them in the car!
joshprescotttttt5
06-15-2009, 10:25 PM
any new pics with them mounted?
looks awesome tho!
Scira
06-16-2009, 04:05 AM
looks awesome tho!
I'd like to see them mounted as well. Interesting project!
