Can i do an SD tune without a wideband?
Old 04-22-2009, 07:38 PM
UnZFeat'd's Avatar
Default Can i do an SD tune without a wideband?
i ported and polished my MAF, then i got another one at autozone and they are both doing the same thing. The LTFTs go way up and are pegged for most of the time. Then, when i unplug the MAF, things are great. MY question is, can i just unplug the MAF until i get a wideband? I just have bolt ons and a fuel pump upgrade. Nothing internal. ...Nitrous, but havent used it yet. How much will this hurt my gas mileage, performance, streetability, etc? Thanks
Old 04-22-2009, 07:47 PM
JDMC5's Avatar
Yeah you can tune without a wideband, just use your fuel trims. When I disconnect my maf my wideband shows decent fuel trims without tuning, however my car is mostly stock except for an intake and catback. Your headers might throw off your VE table but you say it looks good so it should be fine. You are aware that disconnecting the maf will force your car use the low octane tables right? Why not just tune your maf? Do you have a wet or dry nitrous kit?
Old 04-22-2009, 07:51 PM
UnZFeat'd's Avatar
its a wet nitrous kit, but i ported my MAF and i cant figure out how, for the life of me, i can get this thing to work without the screen and the airfoils for some reason. It just always makes my LTFTs jump to the red
Old 04-22-2009, 07:55 PM
UnZFeat'd's Avatar
what does the low octane tables mean? Im assuming it doesnt mean that i can start suddenly running 87 octane on this right? Or does it mean that it will tell my car to automatically detune the car as if it WERE running the lower octane gas?
Old 04-22-2009, 08:04 PM
JDMC5's Avatar
correct, it will default to the low octane timing table which is less aggressive than the high octane table.......yeah, don't use 87 octane. Have you tried scaling the maf up like 10% or so?
Old 04-23-2009, 08:02 AM
YellowToy/A's Avatar
You have no idea what ur A/F ratio at wide open throttle is. If it is lean it is hot. I have seen more than few engines with problems from this. Get a wide band do it right. They are not that much.
Old 04-24-2009, 03:23 AM
MrDrezzUp's Avatar
You can tune the car for SD without a wideband but it should only be done to allow you to drive the car (no WOT/PE) until you get a wideband.
Try adjusting your MAF Airflow table(s) based on the results of your logging. I recently made a number of changes to my car and the LTFT (when MAF is enabled) go 25%+ right away. I assumed something was wrong but after a bit of logging and MAF Airflow adjustments it appears that my MAF Airflow table might just be that out of whack after my recent modifications.
Old 04-24-2009, 01:30 PM
UnZFeat'd's Avatar
here do i find the MAF airflow table? and how should i go about tweaking it?
Old 04-24-2009, 01:50 PM
did u get a wide band?
Old 04-24-2009, 02:00 PM
UnZFeat'd's Avatar
no not yet
Old 04-24-2009, 02:15 PM
69LT1Bird's Avatar
what are you tuning with? I find it hard to believe that a stock MAF that has been ported will cause this issue.
Old 04-24-2009, 03:21 PM
UnZFeat'd's Avatar
tuning it with HPtuners.
Old 04-24-2009, 04:04 PM
69LT1Bird's Avatar
your tune and a log might be a good idea
Old 04-25-2009, 04:14 PM
JDMC5's Avatar
when I ported my maf on my LT1 my trims went way positive also. Its because the maf area has been increased so you are actually flowing more air than recognizes. You have to skew the entire maf curve up to compensate. I'll never waste my time doing that again, gains are minimal and its a hassle. Have you tried adjusting the maf yet?
Oh yeah, post a log already haha.
Old 04-25-2009, 04:31 PM
Frost's Avatar
https://ls1tech.com/forums/pcm-diagn...ar-dies-2.html
