How much Boost R U Running?
Old 04-22-2009, 07:43 PM
InsaneDomestics's Avatar
Default How much Boost R U Running?
I was wondering about you guys with 1000+HP, How much boost are you guys running with your Turbo(s)? If you have Dyno Sheets Please Post...Thanks!
Old 04-22-2009, 10:56 PM
MY99TAWS6's Avatar
Fairly meaningless question. Since turbos differ big time according to airflow. So big turbo might be able to do 15psi and get 1000hp and smaller ones might need 30.
But ok with my current slightly modified aps setup hope to hit around 1000 engine hp at maybe 18psi on my built 408. Assuming can hit about 100 lbs of airflow at 18psi or so, 50 lbs airflow per side.
If I had say 65lb /min turbos then might hit 1000 engine hp at 15psi on same engine.
So really you want to know what turbos and boost with those turbos and all the relevent engine details. Turbos will hit max power at lower boost on a bigger motor and also depends on how the motor is built up. Better flowing heads and cam also mean max power can happen at lower boost.
Its all about aiflow.
Old 04-22-2009, 11:05 PM
52172's Avatar
99 ta is a talker, but he will answer your question after a couple paragraphs. I think he typs 90 words per minute.
Old 04-22-2009, 11:09 PM
MY99TAWS6's Avatar
Pretty much true..I do type super fast..took typing in high school . I actually wear the letters off my keyboard every few months. So yeah as easy for me to type a paragraph as for most to type a sentence. And my spelling aint too bad either!
Old 04-23-2009, 12:21 AM
Ok, well Im just now getting into the whole Forced Induction thing so Im still learning new stuff. So say I was using Twin GT-K Turbos from Turbonetics on a 427. Could you give me an estimate of boost pressure to get 1000+HP
Model - GT-K 550
Horsepower - 500-600
Turbine Housing - T3 .82 A/R 4 bolt
Compressor Inlet/Outlet - 4.0'' / 2.5'
Old 04-23-2009, 05:57 AM
Fireball's Avatar
24psi
1213 RWHP
Old 04-23-2009, 06:23 AM
sujomatt's Avatar
uh wait its only good for 500-600? wouldnt that be wayyyyy out of its efficiency range? lol
Old 04-23-2009, 06:26 AM
Fireball's Avatar
he said twins...500-600 each
Old 04-23-2009, 11:53 AM
Originally Posted by Fireball
24psi
1213 RWHP
How did you come up with those numbers?
Old 04-23-2009, 11:57 AM
Banned Village Idiot
LS1BLKSS's Avatar
how much boost r "u" running when typing lol
Old 04-23-2009, 12:20 PM
Fireball's Avatar
log file said 24 psi and dyno read 1213
Old 04-23-2009, 12:26 PM
98Camarod's Avatar
lol, I think he is asking about how much boost and horsepower will the 427 make with the turbos he listed now.
Old 04-23-2009, 12:33 PM
Fireball's Avatar
no he asked for dyno #s and boost #s from 1000+ hp cars...
Old 04-23-2009, 12:58 PM
bravoboost's Avatar
There are way too many variables involved between different setups to be even a little bit accurate given such limited spec's. B/c of back pressure increases being a bi-product of big cubed turbo cars, if your looking to make big #'s its usually a good idea to keep the cubes under 400....otherwise your going to peek out on your power b4 you get the boost up.
Old 04-23-2009, 01:02 PM
Fireball's Avatar
nah...just run bigger turbos
Old 04-23-2009, 01:06 PM
bravoboost's Avatar
but then spool suffers right!?
Old 04-23-2009, 01:11 PM
So do you think the Turbos I mention'd earlier would be big enough for the 427 or do I need to go bigger?
Old 04-23-2009, 01:21 PM
Fireball's Avatar
I'd personally go with something on a T-4 housing...
Old 04-23-2009, 01:35 PM
Something such as this Maybe???
Models - GT-K 650
Horsepower - 575-700
Housing - T4 .68 A/R V-band 3''
Compressor Inlet/Outlet - 4.0'' / 2.5''
Old 04-23-2009, 01:41 PM
brians91formula's Avatar
24psi
1213 RWHP
HOLY ****!!! whats it like to drive that thing ?
Quick Reply: How much Boost R U Running?
