Bad vibration at 130+
It actually starts around 100 and gets worse. By 130 its terrible.
I did some more expreimentation and if you "float" the gears around 100. Meaning not accelerating or decelerating, just going steady, the vibration goes away. Bit if you let all the way off, or floor it, the vibration comes back strong.
Ideas?
Ideas?
I would check the tires for balance before going too far as that is probably the most likely and easy to fix. Then go on to drive-line components...that's just my two cents though. Could also be in the wheel bearings or something as well. Once you get into those kinds of speeds, it could be anything that would normally not vibrate enough to feel or matter, but at 130+...
