Headers mid or long lt1
Old 04-22-2009, 09:35 PM
CARFREAKS's Avatar
Default Headers mid or long lt1
I had long tubes in one of my camaro's that wa lowered and they scraped on inclines do long tubes scraped ever with stock suspension in like a 1995 camaro?
Would you do long tubes or mid? I have a 383 with a lt4 hot cam heads and intake would mids flow enough? Even with a 150 shot?
Old 04-22-2009, 09:39 PM
gregrob's Avatar
LOL Let the flames wars begin.
You soon get the "LT'S F T W BITCHEZZZZ!!! crowd in here"
The truth is you should match your headers to your setup.
I like AS&M headers for a street car. For a more top-end / race setup LT's would probably make a few more hp.
Old 04-22-2009, 10:18 PM
ARCTIC '00's Avatar
Just curious as to why you prefer mids for a street car?
Old 04-22-2009, 10:53 PM
myltwon's Avatar
mids have better ground clearance and if you go with a higher quality mid you'll get the primary diameter of your average lt and the ground clearance of a midlength
kinda best of both worlds
Old 04-22-2009, 11:21 PM
SoxXpupPeT's Avatar
i like my mac mids alot. real good ground clearance. real easy install. and a def performance increase. good mid range. when i do new heads ill also be doing LPP's new LT's to get alittle more out of it.
Old 04-22-2009, 11:23 PM
kinglt-1's Avatar
I went with the kyb agx 8-way adjustable shocks on stock springs. The shocks dropped the car 3/4" which gives the car a bit of a lowered stance, but still maintains good ground clearance. Matter of fact kyb does not reccomend running lowering springs with these shocks. I kind of looked at it as a best of both worlds solution. My Lt's have never scraped anything or come close on this setup.
Old 04-23-2009, 02:53 AM
wrd1972's Avatar
Definitive proof LT's are better than Mid-tubes
Red = previous setup with AS&M mid-tube headers & 30# injectors
Blue = current setp with LPP long tube headers & 37# injectors
Only difference in the above setups were headers. Mid-tubes work nearly as well as LT's at high RPMS but just plain suck in the torque department down low. I was blown away by how much more low end grunt I had when going to LT's. My LT's have NEVER scraped at stock worn spring height.
Old 04-23-2009, 08:33 AM
CARFREAKS's Avatar
Thank you guys! Lt's it is!
Old 04-23-2009, 08:56 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I've used all 3, shorties, mids, and LT. LT are the best. I never had ground clerance issues since the car was never lowered and it was a 383 LT1. I didnt mind shorties because they are an easier install until you get the Y pipe portion.
I hated Mids since they didnt increase ease of working in the engine bay, and the collector is in a crappy place. the only Mid I know of that has a 1-3/4" primary was Arizona Speed and Marine Mids which horrible fitment issues and bolt access.
I did fine with Jet Hot LT headers.
Quick Reply: Headers mid or long lt1
