TSP true duel qeustion
Has anyone run pipes off the tsp duel set up to the back of the car with tips like under the axel i wanted to get a true duel set up but i have a trans am and it would look dum without any tips just wondering if anyone has done this before
yeah trans ams dont look good without tips. My camaro on the other hand 100% improvement i think without tips. The only answer to this question is: sell your trans am, and buy a camaro
ss4luck's pics will tell you the truth, but i would never run an exhaust under the axle, its wayyy too little ground clearance
i can almost guarantee an exhaust leak, at the lowest point, within the first 150 speed bumps you go over
Ask and you shall recieve
the lowest part of the exhaust is actually directly in line with the tires, so any speed bumps or bumps of any kind the pipes get lifted by the tires. ive had it for 6 months (~2,500 miles) and the only reason i had an exhaust leak was because i accidently jacked the car up without removing the back half of the exhaust and the axle knocked 2 bolts loose
