At what power level have you seen air filters become a restriciton?
Old 04-24-2009, 04:20 PM
Zombie's Avatar
Default At what power level have you seen air filters become a restriciton?
Has anyone test air filters for a single turbo? I'm currently running a 4" intake pipe with a 4" K&N cone filter that's not that large. I haven't tried removing it at the track due worring about sucking something in due to the close proximity of my intake pipe to the tires.
What's the most power you've seen made through a single cone air filter?
Old 04-24-2009, 04:43 PM
one fast zo6's Avatar
800 to the wheels
Old 04-24-2009, 05:29 PM
MonochromeSS's Avatar
Move your boost gauge to your inlet pipe and see how much vacuum you're pulling on a WOT run. That should give you some idea of if your filter is big enough or not.
Just interested, what K&N part # are you running?
Old 04-24-2009, 09:00 PM
OUTLAWZ RACING's Avatar
I did 760 with the 4 inch intake and a funky powersports filter. I run the K&N now but dont see or feel a differance.
Old 04-25-2009, 08:12 AM
MIGHTYMOUSE's Avatar
i always run a 4" k&n cone its about 10" long tho
have to assume its making over 1100
Old 04-25-2009, 12:27 PM
Zombie's Avatar
That answers my question right there, thank MM.
Old 04-25-2009, 12:52 PM
single digit dreamer
parish8's Avatar
1000+rwhp with a 4" k&n probably 8" long
there was a time with twins and a pair of low priced spectre filters when we took the filters off for a run and then put them back on. no diference in numbers. that was at around 500rwhp each.
Old 04-25-2009, 01:11 PM
LS1Tech Sponsor
hellbents10's Avatar
Greatly dependent on size. For instance the 10" long 5.5" inlet K&N we use for the BW turbos shows no drop in power to 1000hp.
Old 04-25-2009, 01:14 PM
BadgeZ28's Avatar
K&N gives CFM numbers for their filters. I would guess you guys setups are passing well over 1000 cfm at WOT?
Old 04-27-2009, 06:31 AM
Denali08's Avatar
What part# will fit S91?
Quick Reply: At what power level have you seen air filters become a restriciton?
