What all is needed for swapping a non egr provision intake on a 98' z28?
What all is needed to swap to a ls6 intake from the 01-02 ls engine to my current 98' z28 would it run like **** without a tune since i wouldn't have the egr on or would it run o.k. Or would it be cheaper just to get the ls6 intake with the egr on it already?
Location: Your girl's back door giving her the long stroke while you're at work
You'll need to remove all your EGR stuff and make a block off plate of the port on the exhaust manifold. Then you'll have to have the code deleted out of the PCM. Pick up a new set of intake gaskets for $30 and don't break the oil pressure sending unit
Good Luck
Good Luck
