Drag Racing Tech
Anybody ever plugged a slick?
Old 04-25-2009, 12:05 AM
jcoker's Avatar
Default Anybody ever plugged a slick?
Had a screw in the middle of my slick and just wanted to know if its safe to plug or patch.
Old 04-25-2009, 12:18 AM
hlaalu's Avatar
that's a good question. On one hand, the psi is very low, but on the other hand, those tires take some serious abuse at the track. I do have a friend who plugged up one of his track tires. They weren't "slicks" though.
I'm curious to know the answer to this as well
Old 04-25-2009, 01:24 AM
EHat911's Avatar
go buy inner tubes.. problem solved!! but id still put a patch over the hole so it doesn't rip bigger
Old 04-25-2009, 05:45 AM
DiabloFormula's Avatar
I had my one ET Street Plugged awhile back and have done many many burnouts and runs with no leaking and no problems, running 13-15psi at the track in it as well.
Old 04-25-2009, 06:50 AM
mike c.'s Avatar
I did. I had no tubes but added them after I pluged the tire. never had trouble.
Old 04-25-2009, 01:04 PM
Black94Z28's Avatar
i work for a tire shop (goodyear) and if done correctly, the patch will be the stongest part of the tire and you should never have an issue
Old 04-28-2009, 07:44 PM
jcoker's Avatar
Had them do a patch plug combo thing with some kind of glue. Worked good enough to pull the tires a few times. I haven't put any air in it yet either.
