Favorite rear end gear ratio (m6)
Old 04-25-2009, 12:40 AM
brianfromhawaii's Avatar
Default Favorite rear end gear ratio (m6)
I have a 400 wheel horsepower camaro (confirmed today... woop!) without spray too...
anyhow, I want to pull a bit harder, what gears should I gear? Stock 3.42 right now, I can get my hands on some 3.73's or 4.10's pretty cheap with an install kit.... suggestions anyone?
Old 04-25-2009, 12:52 AM
also - anyone know some good calculators so i can see at what rpm = what mph?
Old 04-25-2009, 01:36 AM
conan's Avatar
4.10's are probly the most favorite here. When I get my 12 bolt I'm going to get 3.73's. I like the way the car drives with the 3.42's now so I don't want to change it much. This car is a street car not a track car so I'm not looking to cruise down the high way and have the rpms up very high.
https://ls1tech.com/forums/gears-axl...ere-first.html
Old 04-25-2009, 07:14 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
4.10s
Old 04-25-2009, 07:37 AM
amsoilguy's Avatar
4.10s with M6. no doubt! I'm 400hp with m6 and 4.10s perfect setup for me. great on the highway in 6th. I needed the gears for the cam so its like a new car to me. I have the the 10bolt housing and I would NOT go this route. I had no choice at the time so i had to do it. I hit 3rd and pinion turned to a powder. lol. my car is a dd so it had to go back on the road quick.
Old 04-25-2009, 08:55 AM
KENS_SS_4's Avatar
I cruise in my car all the time. I wouldn't have anything but the quiet of my stock 3.42's.
Old 04-25-2009, 09:19 AM
spaz1's Avatar
4.10's aren't noisey if they are set up properly.
Old 04-25-2009, 03:13 PM
flintwrench69's Avatar
I got 3.73s, what was in mine when I bought it so I dont know what the 3.42s are like. At 80 in 6th I am at 1800 rpms. 4.10s seem to be the favored gear upgrade for an M6 car, I do like my 3.73s though.
Old 04-25-2009, 04:05 PM
tj1986c's Avatar
I plan on going with 4.10s myself.
Old 04-25-2009, 05:38 PM
99345hp's Avatar
i had 4.10s in my rearend before it blew up. I got better gas mileage with them than i do with the 3.42s. I have heard of people with 12 bolts going with 4.56 gears with good results.
Old 04-25-2009, 05:41 PM
Martin HD-28's Avatar
Which is going to read lower on a dyno, 3.73's or 4.10's?
Old 04-25-2009, 07:02 PM
01ssreda4's Avatar
i agree, 4.10s is one of the most liked gears for the M6.
Old 04-25-2009, 07:26 PM
TurdsOfMayhem's Avatar
I have always been told by many shops 4:10's in a stock rear equals bad news bears. I had experience with 3:73's when I had a formula, and I liked them. (it was an M6) 2nd gear and 3rd seemed to pulled much harder, 1st was still kinda a dud though. lol
Old 04-25-2009, 07:46 PM
madmike9396's Avatar
Im going 4.56
Old 04-25-2009, 09:26 PM
4WOFURY's Avatar
I have 4.10s in my 7.5" 10 bolt with no problem. I'm pushing ~430hp, and have given it some hell with a couple launches and clutch dumps, but I don't make a habit of it. I shift it hard when WOT.
My tires are 295/18 gsd3s, so they have some decent grip, but they aren't drag tires by any means.
Holding up fine, no noise.
Old 04-27-2009, 06:05 AM
silverM6TA's Avatar
your a lucky man.
Old 04-27-2009, 08:27 AM
WS6R6's Avatar
Happy Medium. 3.90's! But really if it's only between the two I would go with the 4.10's depending on your driving habits and what you are looking to get out of the gears!
Old 04-27-2009, 08:43 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Sounds like you have 3.42s.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-27-2009, 09:19 AM
deelong4002's Avatar
I was going to say the same thing.
Old 04-27-2009, 09:28 AM
LS1Formulation's Avatar
If you have a ten bolt with 400 RWHP and you go to the track, it's going to break. With that said, I have found through trial and error that 4.10's break more often than 3.90s. The pinion is a bit larger on a 3.90 so the tooth contact area is stronger. When I get my S60 in a month or so, I am going with 4.10s again because it can handle it.
Quick Reply: Favorite rear end gear ratio (m6)
