Leather is done
Leather is done
Just need to tighten the passanger seat some more got a little out though.
http://community.webshots.com/album/79456660FVNfJs
LS1Tech Administrator
Received 1,492 Likes
Looks great! I think one day I'm going to do my seats in two-tone.
Originally Posted by ta12sec
I can only hope mine turns out that good
One thing that is handy to have to do the door panels is a dremel. This will help you grind the plastic off and get the cardboard off to put your new skin. GM doesnt use srews on the panel they melt the plastic . So you will only use the screws for the arm rest door handle and part of the speaker form. The rest have to be glued. I seperated the panel skins. Then I took off the oem skin. Then I just traced it on the backside of the door skin with a sharpie. Then I put it on the cardboard to make sure it covered everything and cut it and used a razor knife to make the holes and slits for the tabs. Then I used fabric glue in the spray can 3m makes some real good stuff. Then pasted it together and did all of the above to put it back together.
Originally Posted by Nine Ball
That looks kick ***! So much nicer than factory pleather feel huh?
Tony
Tony
