help reading compressor maps?
Old 04-26-2009, 07:14 PM
Nimitz87's Avatar
Default help reading compressor maps?
looking around here, forcedinductions.com and turbomustangs.com to try and learn me some stuff about turbos
looking to run a 370 LQ9 truck block, 317 heads, 233/233 .585 116 +4 gives me an overlap of 1
9:1 SCR
6.60:1 DCR
turbo would be a T6 GT-47 88 .96 A/R 3" charge pipe, 4" downpipe, 10lb's or so for the street and trying to figure out what rpm I would be at that boost level
here is the air consumption for a 370 ls1
http://www.forcedinductions.com/consumption370.htm
and the T88 compressor map...
http://forcedinductions.com/_derived...tm_txt_t88.gif
PR = 1.68
using
(CID × RPM) ÷3456 = CFM
370x4200 / 3456 = 450 CFM
then multiply for VE
× 0.85 = 445.7 CFM
= 382 CFM turn that into by X 0.69 = 26lb/min
think I'm definitely doing something wrong...that says I'll only be making 4lb's of boost @ 4200rpm?
someone please help the math challenged?
edit: 3.30 rear gear.
Chad
Old 04-26-2009, 08:14 PM
topend's Avatar
take your 26lb/min and multiply by 1.68 PR = 43lb/min
looking at the map its close to surging but that depends on the turbine u use.only realworld testing will tell u.
Old 04-26-2009, 08:35 PM
Nimitz87's Avatar
thanks, I knew I was missing something.
so how/why would it be surging at 10psi, how would I "fix" that?
Chad
Old 04-26-2009, 09:31 PM
topend's Avatar
Chad
if u were to hit 10 psi at 4200 rpm or sooner u would be close to surging .But thats a big if... most likely u would hit the 10 psi alittle later than 4200 rpm.
Old 04-26-2009, 11:19 PM
Nimitz87's Avatar
I don't understand why its so close to surging on the map at pretty much any boost level, here at 15psi
370x5500/ 3456 = 590CFM
x.85 = 501
x .069 = 34 x2.02 = 70lb/min
so looking at the map at a 2.02 PR and 70lb min I'll be at 15lb of boost at 5700rpm but right at the "surge limit" according to the T88 map
unless I'm all screwed up...I thought the 370 and 88mm turbo's were good/common setups?
Chad
Old 04-27-2009, 09:04 AM
ModularTurbo's Avatar
1st find cfm unboosted (CFMU):
(C.I.D/1726) X (maxRPM/2)= CFMU
2nd find Pressure Ratio (Pr):
(14.7+Desired boost) / 14.7=Pr
3rd find CFM boosted (CFMB):
CFMU X Pr= CFMB
4th convert CFMB to LB/min:
CFMB X .07= (required LB/min)
5th look at the comp map and use your required LB/min and Pr to place yourself on the map, trying to be in the lower right hand corner of the efficiency islands.
I hope this helps,
Rob@modularturbo
Old 04-27-2009, 10:57 AM
LS1TECH Sponsor
DrTurbo's Avatar
x.85 = 501
Chad
You would be fine. The compressor map we are using is the older style 88mm comp wheel. The newer style is much broader so no worries about surge.
Old 04-27-2009, 12:08 PM
Nimitz87's Avatar
CFMU X Pr= CFMB
I hope this helps,
Rob@modularturbo
Rob THANKS alot, really appreciate that...I think something like this should be in the FAQ's/sticky's and that puts me in a way better spot on the map I knew I was doing it wrong...
good to know...I knew everyone running this setup couldn't be having those issues.
Chad
Quick Reply: help reading compressor maps?
