Turn signals acting up
Old 10-29-2003, 09:32 PM
Bigvic's Avatar
Default Turn signals acting up
Today when I first used my turn signals they started flashing very fast. In the past they would flash at a medium pace, buy today they started spazzing out. I haven't really had time to examine the car much, so I don't know if a bulb is out or maybe my flasher is going out. I just figured that this has probably happened to someone else in the past and they could immediately point me to the problem. Thanks.
Old 10-29-2003, 10:41 PM
Copy & Paste Moderator
VIP1's Avatar
Most likely there is just a bulb out somewhere.
--VIP1
Old 10-30-2003, 09:46 PM
Bigvic's Avatar
OK I checked the bulbs and they all work, so any other suggestions?
Old 10-30-2003, 10:00 PM
wrencher
wrencher's Avatar
Try replacing the flasher, it is located behind the bolster/knee panel under the column.
Where your right knee would be as if sitting in drivers seat.
Old 11-08-2003, 10:59 PM
Bigvic's Avatar
Thank you wrencher, it was the flasher that was bad. I was suspecting that, but without you telling me where it was located, I would never have found it.
