LQ9 Bore ??
Old 04-27-2009, 06:11 AM
super-ss's Avatar
Default LQ9 Bore ??
What is max bore for LQ9 ?
I want (4.155) bore * (4) stroke
Old 04-27-2009, 06:12 AM
SweetS10V8's Avatar
Dont we all?!?!? Get out your check book if you want 4.125
Max bore on a an LQ9 is 4.060"ish
Old 04-27-2009, 06:17 AM
super-ss's Avatar
I see 4.125" ??
Old 04-27-2009, 06:28 AM
SweetS10V8's Avatar
4.125 is the standard bore typically used to get 4.155, 4.125" + .030 over = 4.155.
RHS has a new block that 4.160" and will take a 4.600" stroke that I saw at PRI. 500ci!!
Old 04-27-2009, 07:05 AM
super-ss's Avatar
I want max bore in LQ9 , thanks
Old 04-27-2009, 07:06 AM
GMCtrk's Avatar
4.03" to be safe typically
Old 04-27-2009, 07:10 AM
SweetS10V8's Avatar
Have whatever block you use sonic tested.
Honestly boring to the max is a complete waist of a good block. YOu should run the least amount of bore that you can. That way if you engine dies, you can still bore it and rebuild.
THe difference between standard bore and max bore is probably less than 5-10hp
Old 04-27-2009, 09:15 AM
goober35's Avatar
4.060 is a max bore. But it has to be tested. Just spend the extra cash on a stroker crank and get a 408.
Old 04-27-2009, 10:21 AM
PREDATOR-Z's Avatar
LSx block
Old 09-26-2009, 10:08 AM
89LS1RS's Avatar
LSx block
thats the way to go
Old 09-26-2009, 10:19 AM
DVS99TRANS's Avatar
^^^ yup, LSX. 408 is the biggest you want to safely go with it if you plan on making power.
Old 03-24-2010, 07:32 AM
super-ss's Avatar
I want use the LQ9 block with 4.125 bore with LS7 Cylinder heads .
Is it safely ???
Old 03-24-2010, 07:44 AM
JP
JP's Avatar
Is it safely ???
Are you reading the thread?
Old 03-24-2010, 09:44 AM
1CAMWNDR's Avatar
It has been done before but with the water jackets filled all the way to the top of the deck (no coolant) and on a race only engine. Mine is 4.07" and is half filled (up to the water pump ports). IF your block can take a 4.06" or 4.07" bore that is as far as I'd go IF you are willing to half fill it.
Old 03-24-2010, 10:28 AM
the_merv's Avatar
Is it safely ???
Not going to happen unless you sleve it.
.030 over safely, .060 over and have it checked.
Quick Reply: LQ9 Bore ??
