p1sc install on lt1 i need some help please
hey guys installed my p1sc on my lt1 yesterday the issue that im having now is with the pulleys i put the stock balancer/pulley on then the procharger spacer then the procharger pulley put all 3 bolts in with a washers got all 3 bolts reall tight and the stock pulley is loose are there suppose to be some spacers or something to get the stock balancer tight
1- Did the bolts they send you run out of threads?
2- Did the stock balancer/pulley's rubber piece slip and now its wobbly?
3-Did you tighten them down slowly together? When I put mine on I do them all hand tight, then go back and snug them, then tighten them up so it pulls itself on level and not all cockeyed.
Thats all I can think of.
