seafoam???
Old 04-27-2009, 01:52 PM
1toofastlt1's Avatar
Default seafoam???
I have a 97 z28 with 141K on it. should i run seafoam? dose this stuff work?
Old 04-27-2009, 01:56 PM
kinglt-1's Avatar
yea it works good. Just make sure you put it in thru a vacuum source on the intake manifold. Do not put it directly into the oil.
Old 04-27-2009, 01:59 PM
dilatedpeoples28's Avatar
http://www.lt1engine.com/tech/how-to...arbon-buildup/
put it in the oil, just gotta remember to change it shortly after
Old 04-27-2009, 02:00 PM
I look at the can and it doesn't really say how to use it. would i just put it in any vaccume line?
Old 04-27-2009, 02:03 PM
complete writeup above
Old 04-27-2009, 02:06 PM
kinglt-1's Avatar
Ok I know somewhere I read not to directly add this to your oil. But the link above is from a reputable source, so give it a shot i guess...Just follow the steps in the link above. I am always leary about adding stuff to the oil, not trying to spread bad info either.
Old 04-27-2009, 02:10 PM
nah its understandable, its not normal to put anything besides oil in there. Ive done it numerous times on mine and other cars and never had a problem.
Old 04-27-2009, 02:11 PM
deelong4002's Avatar
It works. Follow the write up, i think you'll be suprised
Old 04-27-2009, 02:19 PM
ok thanks guys
Old 04-27-2009, 02:25 PM
collier341's Avatar
seafoam is great! put it in my oil about a week ago and just changed it.. no problems just a clean engine
Old 04-27-2009, 02:54 PM
nik1703's Avatar
Does anyone notice a difference after using this stuff? or is it all mental?
Old 04-27-2009, 03:01 PM
djjab57's Avatar
is it true that if you have oil leaks it will make them worse ?
Old 04-27-2009, 03:05 PM
collier341's Avatar
when i used the spray can seafoam and directly sprayed it into the intake, i definitely felt a difference after.. the idle was smoother and the car just seemed to be running cleaner
when i put it in the oil i felt no difference at all.. the oil was extremely dark when i changed it tho
Old 04-27-2009, 03:31 PM
Breathing Fire's Avatar
Would it work the same for the ls1?
Old 04-27-2009, 03:57 PM
TurdsOfMayhem's Avatar
My idle became much smoother, and got much more responsive in the lower RPMS, completely eliminated the slight hesitation I had.
Yes. Very easy and inexpensive to do. Worked great for me.
I was leary(sp) like several other people, especially when it came to putting it in thru the brake booster line, but everything went accordingly.
Quick Reply: seafoam???
