Help with 600 HP Rear mount
I am going to be starting a build up on a 2000 Trans Am. This is gonna be a rear mount build keeping all the DD stuff in it. The goal is 600hp with a forged aluminum bottom end. Im looking for all the suggestions and ect. Wanna make this a nice DD car with quick spool and a blast on the streets.
Car:
2000 TA
M6
Bone Stock
AC
DD
Reliable.
Plans:
Forged Engine
Tick Tranny
Midwest Chassis 9 inch 3.45 gear
All suspension Mods
The first step in the build is going to be a rear mounted turbo kit, engine and rear end and .
Motor Work
Rods?
Pistons?
Stock Crank
Stock Heads
Cam?
Turbo Kit
Need help sizing a turbo for both fast spool and power Masterpower T70 with a .68 ar?
We are going to get the car this weekend and will pry order everything we need as well.
Looking for suggestions.
Car:
2000 TA
M6
Bone Stock
AC
DD
Reliable.
Plans:
Forged Engine
Tick Tranny
All suspension Mods
Motor Work
Rods?
Pistons?
Stock Crank
Stock Heads
Cam?
Turbo Kit
600whp or 600bhp? Assuming whp.
My setup is overkill for what your goals are but here it is so maybe you can get some ideas.
I use a Callies Dragonslayer crank, forged everything, 383cid
Cr is about 8.7:1
Bauer custom turbo cam
Dart Pro1 225 heads
Nick Williams/FAST 90
4" FMIC
SD tuned
GT76, .81 ar
60# injectors
And all the other things that add up
I think the T70 is a good choice if all you want is 600whp. Someone else can help you size the one you need better. Keep the cubes between 370-383, get a good IC. Maybe call Bauer and have them do the cam for you.
Cr is about 8.7:1
Dart Pro1 225 heads
4" FMIC
SD tuned
GT76, .81 ar
60# injectors
At 600whp, you are pushing it. Some have done it successfully, but the pages of this website are littered with #7 ringlands and broken dreams from those who have not.
I would strongly suggest conservative tuning, a strong fuel system, an intercooler, and <550whp on a stock LSx rotating assembly. Looks like the OP has the intercooler covered.
As for meth, it is just a band-aid substitute for good gas IMO. If you use it, tune it as if you did not have it, or there's no point...because if you run out when you need it, you've got problems.
Update:
Motors in and I ran into 1 snag so far. I overlooked the 6.0 crank spacer, got that pulled back apart tonight. Trannys in,tq in, Need to finish the wire tuck hook up exhaust and charge pipes, fill fluids and should be ready to deliver on friday.
Ill get more recent pics later after I finish everything.
The white paint will all be gone one he pulls the bumper to paint.
Updates off camera phone pics. Photo shoot will be soon.
Its all jambed and wet sanded color and clear should be sprayed tonight. Sit out all day tommarrow and buff tommarrow.
Here is a pic of the body before wetsanding and buffing.
Cant wait to see it in the sunlight. Indoor does the color no justice.
Late update!
Late update!
I did not read eveyones post.. But I has a STS GT70 on my formula that was slightly modified.
60 lbs injector and a FMIC
I stoped at 605rwhp and I was doing that with 12psi. My spool was not that good but I did not have my exhast raped up.
But 12 psi was the magic # for me
If your car was only pushing 300rwhp stock you would then need 14.7psi give or take psi to double it.
