How does this Pressure Plate look?
I would say it's usable. It has a few hot spots but I've seen MUCH worse before with cars that didn't have any issues driving. But it might be worth it to have it resurfaced just in case. I could see how it could only have 200 miles on it, maybe 200 miles of teaching someone how to drive a stick though. With 200 miles it shouldn't look like that.
Well. it really doesn't look that bad. You can tell that it really wasn't seated very well, and that as a result that it slipped a bit. But in order to better understand the amount of wear present I need you to mic the disc thickness. The disc started at .310" thick and any more than .025" wear will mean that the disc needs to be replaced. Once I have this info I can tell you more. Thanks!
