i need a good trans cooler help me
Old 04-27-2009, 11:30 PM
chucks ss's Avatar
Default i need a good trans cooler help me
i need a good trans cooler , overkill is fine with me as long as its not too expensive , im running a 4l65e i run my camaro hard and i have had trans problems numerious times and after the third trans i just want to cover all my bases looking to spend $200 bucks give or take ive seen two styles the long style and the flat radiator style opinions and advice on which is better and am i going to have to do allot of work to install this thing? , thanks for your time and help
Old 04-28-2009, 07:04 AM
koolaid_kid's Avatar
There are several good brands out there, Hayden and B&M being two of them. The plate types are supposed to be more efficient than the tube types. With your demands, you may want one with a built-in fan. You may also want a thermostat. An example is the B&M 70298, which has both, but needs an installation kit.
The install is not difficult at all, and it is generally recommended that you take the factory radiator out of the loop.
I use the 70264, and my temps are always below 200, even when I run it hard.
Last edited by koolaid_kid; 05-01-2009 at 08:50 AM. Reason: corrected model number
Old 04-28-2009, 04:50 PM
chucks ss's Avatar
thanks that helps allot cause ive been through a couple of trans missions ,and anything that will help is all the more
Old 04-29-2009, 04:23 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Hell if you are planning on spending $200 on it then get the one with the electric fan attached
Old 04-29-2009, 12:23 PM
LSXFORMULA99's Avatar
i got one from the local parts store that is made for a RV. so its really big.. it was only like 40 bucks
Old 04-29-2009, 03:19 PM
jerjsor's Avatar
Do you run a trans temp gauge?
I just got done putting in a B&M cooler and a temp gauge in the pan with my new converter.
Old 04-29-2009, 08:22 PM
forcd ind's Avatar
i run a B&M one, with the 1/2" pipe threads in/out-i think its like 11" X 12"
i have it mounted under the car at a slight angle to catch air, running a 4l80e and 10" converter, doesnt see much more than 160-170 degs
Old 04-30-2009, 05:32 PM
bigdsz's Avatar
Google Long- Tru Cool Oil Coolers, a 36 pass cooler is only $60. Superb quality.Using one of these coolers dropped my engine oil temp on my 408 from 275* to ~200*.
Old 05-01-2009, 07:41 AM
barnat's Avatar
Default B&m
The BEST you can get is the B&M coolers from Summit (IMO) and if running Dope style the B&M Part # BMM-70264 (11"BY 6") ARE THE BIGGEST YOU CAN FIT UP IN THE FRONT CORNERSI ran 2 of em which i know wasc overkill ,but looks basd *** LOL The coolers are 59.99 each My ***** at 160 all day long in the summer with no fans and running hard too!
http://s243.photobucket.com/albums/f...view=slideshow
Old 05-01-2009, 09:22 AM
cause4panic's Avatar
Long tru-cool
Old 05-01-2009, 01:53 PM
sman's Avatar
Hayden is the best quality Ive every seen on one of these. I got the biggest available, ran about $60 IIRC.
Old 05-01-2009, 03:27 PM
trans2000am's Avatar
i got mine from ATI its a derale-the atomic cooler comes with fan it was 200 bucks tho but ill never have cooling problems
Old 05-01-2009, 09:17 PM
CoolAid's Avatar
Derale Atomic Cool
Derale deep cooling tube pan
LOL @ B&M being the best possible. It would be fine with your 2,800. But if OP ever steps up to a 4,000+ click the above links and call it a day.
Old 05-01-2009, 11:43 PM
KL20's Avatar
i've got a B&M supercooler attatched in front of my radiator. it's all connected together. works great for me, i've got a Vig3600 and it's been in for over 6 years now. haven't raced since '04 so i only daily drive but it had its fair share of hot lapping back before.
Quick Reply: i need a good trans cooler help me
