Warning for those running 16" pusher fans
Old 04-28-2009, 10:04 AM
Fireball's Avatar
Default Warning for those running 16" pusher fans
Had an issue last year with something pressing my pusher fan into the rad
Bought a new rad and redid it making sure nothing was touching the fan housing or motor body... Even with nothing touching and 1/4" clearance between the fan and the rad, the f'in thing did it again...
whats wierd is that there was contact after 1/8 mile passes 3 weeks ago (I had the fan off for some maintanence)...but after my last 1/4 mile pass this past weekend...oops I did it again
Hypothesizing that its from wind pressure at 160+ mph..but not 100% certain...I think I'm going to add a piece of 1/8" aluminum bar inbetween the fan and the rad to keep it from happening a lucky third time
Old 04-28-2009, 10:18 AM
kp
kp's Avatar
Make sure the fan isnt running during a pass?
When they are running they are more of a solid piece at 160mph that something the air can go through.
Old 04-28-2009, 10:22 AM
Fireball's Avatar
hmmm...interesting idea....
fan was most definately on that last pass based on coolant temps...
Old 04-28-2009, 10:28 AM
kp
kp's Avatar
Once you pass the rated CFM that fan may as well be a piece of cardboard, thats why most stock setups turn off at a certain mph, they are more of a restriction when they are running at high mph. Unless of course you have no natural airflow like a rear mounted trans cooler its best the fan(s) turn off. Kind of a PITA, another switch to remember, so you are probably better off getting it further from the radiator..
Old 04-28-2009, 10:49 AM
veee8's Avatar
We were wondering about this last weekend. The BS3 just commands them on and off at coolant temps. Now I know they are coming out with a software update to use a hysteresis like the stock setup to turn them on and off. Not sure if it is out, and how it works.
Old 04-28-2009, 10:53 AM
kp
kp's Avatar
Yea, BS3 is just temp based, I used a WOT TPS nitrous switch to turn off the fans in my old car with the BS3, this one has a stock PCM and I turn them off at 35mph. I dont have pushers but thats 25 amps of current draw I dont need going down the track
Old 04-28-2009, 12:39 PM
MeanYellowZ's Avatar
yup, this is the way to go. You can wire up a WOT switch easily using relays and turn off any fans during full throttle runs.
Old 04-28-2009, 12:59 PM
bumpin_records's Avatar
very good idea.
Old 05-01-2009, 05:07 PM
Fireball's Avatar
knocked 6 holes in the tubes
found this stuff called superalloy1 which is a 350* solder for aluminum...seems to have worked well...holds 16 psi of water pressure back w/o any leaks
Quick Reply: Warning for those running 16" pusher fans
