Pat G custom cam results.
Old 04-28-2009, 04:16 PM
BlkBird2000's Avatar
Default Pat G custom cam results.
Finally got my cam put in. It's a 226/232 .609”/.604” 113LSA +2 advance. Pat made this cause I want to throw a 100 shot at it later on. So the results are not the greatest. I can't wait to throw the bottle on and see what she will do! Here are the results. About 385/360. Before was 345/355. My peak numbers are not the best but it holds power for a lot longer. My tuner said the gap you see is from having msd wires. He said they are thicker and it's hard to the thing that grips one of them to read what's going on... if that makes any sense to you guys?..
Old 04-28-2009, 04:17 PM
The modifications I added along with the cam is a UD pulley and a ls7 clutch kit.
Old 04-28-2009, 04:23 PM
95Lwind05's Avatar
Looks like some pretty solid numbers for the mods done!
Old 04-29-2009, 10:27 AM
T.A.WS6
Guest
Posts: n/a
nice!!!
Old 04-29-2009, 02:06 PM
NBM-LS1's Avatar
Saw it you yesterday. Nice numbers! Car looks fantastic!
Old 04-29-2009, 02:46 PM
Thanks man!
Old 04-29-2009, 04:08 PM
Chris05ssTruck's Avatar
Where is the tq????
Bottle will make up for it tho lol!
Old 04-29-2009, 04:21 PM
greatskiiiier's Avatar
my dyno had a gap in it too, thought it could have been a miss fire- now i know the truth
Old 04-29-2009, 06:24 PM
Nitroused383's Avatar
Keep in mind they say the LS7 clutch robs about 10hp on the dyno. Did you use the LS7 clutch and flywheel, that is the setup I have and its a heavy bastard.
Old 04-29-2009, 10:14 PM
Yea I have the heavy ls7 clutch along with some 4:10s. I'm going to go to a dyno day sometime and see what it does on a different dyno. For the cars I run with, the numbers don't make much sense. But oh well, i'm not really a dyno number freak. I knew what kind of na numbers i would be getting with this cam.
Old 04-30-2009, 02:20 AM
cals400ex's Avatar
who tuned it for you? i am in the area, that is why i ask.
Old 04-30-2009, 04:45 PM
Keith McCord. He doesn't have his own shop or nothin. He uses people dynos. PM me if you want his info.
Old 04-30-2009, 05:50 PM
BIG_MIKE2005's Avatar
Nice numbers man.
Old 04-30-2009, 06:10 PM
airforcemanss's Avatar
thats going to be a fun setup w/ the nawwwz.
btw, in your sig whats a upper and lower phb? do you mean the phb reloc for the true duals?
Old 04-30-2009, 06:16 PM
Yea. I run 2.5 true duals out the back. I don't have it in yet. Hoping it will solve all my exhaust banging problems!
Old 04-30-2009, 06:18 PM
Check into either new poly motor mounts or solids too. That will also help with exhaust hitting in certain places.
Old 04-30-2009, 07:33 PM
Yea I've thought about those too. Not sure I wanna go through installing them lol
Old 04-30-2009, 07:42 PM
01FbTaWs6's Avatar
hmm, numbers do seam a little low to me. That cam should pull quite abit better then that i would think. Somewhere closer to 400 rwhp and 380 ish rwtq I would think
Old 04-30-2009, 08:58 PM
cals400ex's Avatar
i hear he is a good tuner, just hard to get ahold of.
Old 05-01-2009, 12:04 AM
Yea a little. I'm going to head to another dyno to see what kinda numbers will show up.
Quick Reply: Pat G custom cam results.
