Need Help!!!!!!
Old 04-28-2009, 08:27 PM
ls1347ta's Avatar
Default Need Help!!!!!!
I recently bought a F.A.S.T 92mm intake and PTM 92mm throttle body. I am having a problem with it hanging up. i have put a brand new sensors for the throttle body.and i have also put a new throttle cable on it and its not to tight.i have no vaccuum leak or there is nothing wrong with the tune. i have ajusted the blade on the tb and got it centered up. the car cranks and idles just fine but when u rev it up or driving and let off of the gas the RPMs stay at 1500-1700. if you grab the tb and turn it back it will go back down. i have went through 4 tps b/c i thought they were bad. so any advice will be good.
Old 04-28-2009, 09:43 PM
sroach20's Avatar
some aftermarket tbs have a problem with sticking, was yours new. also make sure to get a delco or wells map sensor. i bought a brand new borg warner tps and it read 2% at idle with the throttle closed. i have also seen problems with standard.
Old 04-28-2009, 09:50 PM
ls1347ta's Avatar
yes the tb was brand new. i bought the borg warner one also. but like i said it idles fine but when you rev it up or give it gas driving it stays at 1500-1700 rpms. and i have a brand new map sensor to.
Old 05-02-2009, 05:13 PM
ls1347ta's Avatar
i figured what was wrong with it. where the iac goes in at there was a bur in it. so we filed it down and the tb works fine now. thanks texas speed
