what is different between these 2 hooker cat-back system ?
Hooker Super Competition Cat-Back Exhaust (1993-1995 Camaro & Firebird LT1)
[16827HKR] $339.95
Price Match Guarantee
Points & Redemptions Credit: 1.69975 Points Currently Valued at $1.70
A Systems exit at stock locations using great looking Hooker chrome large bore exhaust tip extensions (where applicable).
B Each exhaust system is mandrel bent not press bent. Mandrel bending maintains a consistent inside diameter for maximum flow; press bending will crush the pipe, easily reducing volume by more than 10%.
C Most Cat-Back systems feature Hooker Aero Chamber mufflers producing more horsepower and torque than all other popular chambered mufflers with a deep throaty powerful sound that will not change with time.
D Systems are designed using flanged construction (where applicable) and existing stock hangers for easy installation.
E Large diameter 16-gauge aluminized tubing for low back pressure and long life.
and...
Hooker Street Force™ Cat-Back System (1995-1997 Camaro & Firebird LT1)
[16825HKR] $349.95
See larger image
Points & Redemptions Credit: 1.74975 Points Currently Valued at $1.75
Super Competition Cat–Back System Dual Catalytic Converter Black Finish Mufflers with Aluminized Pipes for 95–97 Camaro/Firebird with 350 LT1
Features
• Exit At Stock Locations
• Mandrel Bent Not Press Bent
• Consistent Inside Diameter
• Maximum Flow
• Uses Existing Stock Hangers
• Large Diameter 16 Ga. Aluminum Tubing
• Low Back Pressure and Long Life
• Easy Installation
• Comes with Show Polished Stainless Tips and Aerochamber Muffler
I cant desice between these two.
[16827HKR] $339.95
and...
[16825HKR] $349.95
See larger image
Features
• Maximum Flow
• Easy Installation
