prc 5.3 stage 2.5 vs prc ls6 stage 1
Old 04-29-2009, 11:09 AM
firechicken76's Avatar
Default prc 5.3 stage 2.5 vs prc ls6 stage 1
I've got an mti x1 cam and was wondering which set of heads I should go with. I'm on a limited budget and both are about the same price. I've got an 02 ls1 full bolt ons ford 9" w/ 4.11's.
Old 04-29-2009, 01:02 PM
cam specs are 230/227 dur, .591/.571 lift, 112 lsa
here are the stage 2.5, 5.3's
http://www.texas-speed.com/shop/item...id=84&catid=20
and the stage 1 ls6 heads
http://www.texas-speed.com/shop/item...d=649&catid=20
Old 04-29-2009, 01:11 PM
venom ws7's Avatar
I've bought both heads 8-10 times from TSP For a customers of mine and both made 35+RWHP with only heads swap and tune.
Just be sure to get the heads milled to 59cc this setup will get more TQ and power for sure.
420+rwhp with M6 Is very possible
Old 04-29-2009, 07:13 PM
sully00ws6's Avatar
With a similar setup as the OP's what kind of gain would you expect with the Stg. 2.5 LS6 heads versus the Stg. 1 (from TSP)?
Old 04-29-2009, 09:33 PM
does anyone know what would be better?
Old 04-29-2009, 09:44 PM
vettett15's Avatar
I prefer the TSP stage 1 LS6 heads. 228/232 113+4 MTI G1 cam, ls6 intake, udp
Old 04-29-2009, 09:46 PM
gc302047's Avatar
i want this cam so bad! where did you get it?
i found this thread and its pretty crazy check it out. the guy used terminator heads and made huge power!
https://ls1tech.com/forums/dynamomet...tor-heads.html
Old 04-29-2009, 09:51 PM
dont really care about dyno numbers, i want to make the car as fast as possible, not as much peak hp as possible.
do you have a link to those heads?
Old 04-29-2009, 09:55 PM
ZMONSTER!'s Avatar
PRC 2.5 5.3's(milled to 59cc)+224/228 581 588 114+2=numbers in sig
Old 04-30-2009, 03:44 AM
HTX
HTX's Avatar
that car with the right suspension WILL be fast.
Old 04-30-2009, 05:57 AM
vettett15's Avatar
Who said anything about peak, it makes 300 ft*lbs @ 2250 rpm, don't disregard a setup because it makes decent peak and power under the curve. I understand some people around here hate looking at dyno graphs but it would be a mistake to say that there isn't a good correlation between a car's power and what it can do at the track assuming it can put the power down, etc. The MTI G1 isn't the most up to date cam so I'm sure you can do better than what I have. The heads were milled to 59cc, 11.4:1 SCR and 8.7:1 DCR. http://www.texas-speed.com/shop/item...d=649&catid=40
Old 04-30-2009, 09:37 AM
TXZ28LS1's Avatar
unfortuntately MTI is no longer around. and i think TSP doesnt make the PRC terminators.
Old 04-30-2009, 11:48 AM
will my x1 cam work with milled 5.3 heads to 59cc? or would there be ptv issues?
would compression be fine for pump gas? 92 octane.
Old 04-30-2009, 11:55 AM
vettett15's Avatar
Is there any advance ground into the cam? That will play a determining role if it will work. The MTI G1 cam fit under my 59cc ls6 stage 1 heads. I think the larger intake duration is going to hurt you compared to my cam but I also am on a 113+4 so that didn't help me out either.
Old 04-30-2009, 12:04 PM
no advance ground in.....
Old 07-14-2009, 12:41 AM
KillaCamZ28's Avatar
Theres a lot of ppl running 5.3 heads with a mild cam like yours and hitting 430rwhp ... i like them over the ls6 heads, stage 1 at least... but you'll need a ported ls6 intake or 90/90 to hit those numbers
Old 07-14-2009, 04:54 PM
RedRallyeZ's Avatar
on my A4 with a conservative tune and a TQR III camshaft, i made around 385rwhp and 360rwtq (cutouts closed/converter unlocked) driveability is great. no track times, but is a straightup fast car...
Old 07-15-2009, 05:47 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I really like the LS6 style heads. The Stage 2.5 LS6 heads are definately my favorite, but if your on a budget the Stage 1 will be a great head that can be upgraded as you move on to bigger & better short-blocks!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-06-2009, 05:00 PM
Boehlke's Avatar
Damn, how did I miss this? That was my old car and I sure do miss those heads. I wouldn't mind having another set of those terminators; I've tried to get them from the guy who bought that car from me, but he's not giving them up. I went with a similar setup on my vette with the stage 1 or 1.5 LS6 heads from PRC (I forget), but it just isn't the same... Not to mention I'm no where near that power level.
Quick Reply: prc 5.3 stage 2.5 vs prc ls6 stage 1
