Dyno Guesses & Bench Racing Forum - future mods
mattgt40
04-29-2009, 01:13 PM
if i put all the mods listed below what would my HP & E.T be
current mods
Flowmaster cat-back
cat delete
QTP Electric Cutout
K&N cold air intake
BBK TB
Nitto D/R
Shift kit
3:73 gears
future mods
LT4 hot cam hit
LT1 Platinum PRO1 Heads 180cc/58cc
sub frame connectors
sway bar kit
pan hardbar
lower control arms
PNYKLR-TA
04-29-2009, 04:07 PM
Why hot cam kit? i'd personally scratch that all together.
and if you did all that with a better cam, i'd say HP would be around 350-380 at the rear wheels, of coarse depending on cam like i said.
1/4 Mile time anywhere from 12.5-13.00. Really depends. Also if you are gunna do that, i'd throw in an aftermarket stall converter with a higher stall speed than stock. That will drop you nearly .5 in the 1/4 mile.
AznMuscle
04-29-2009, 04:10 PM
Ben, don't you have a hotcam :confused:
Sarge_13
04-29-2009, 04:11 PM
15's. It is an automatic LT1 after all...
AznMuscle
04-29-2009, 04:19 PM
LOLOL. Sad thing is...that is what they run here.
PNYKLR-TA
04-29-2009, 04:31 PM
NO! i have a Speed Inc Custom Grind EH! The Cadillac Cam :pimp:
thanks jerk! i ran a 14.0 stock auto haha with only 3.23 gears too :cry:
and LS1's run 14's so that doesnt make it all that bad :confused:
AznMuscle
04-29-2009, 05:10 PM
1) WTF is a cadillac cam. Specs, n00b.
2) No, MY ls1 runs 14s here....better drivers run high 13s :angel:. Ass.
PNYKLR-TA
04-29-2009, 05:16 PM
You're a dickweed kyle haha! better drivers run high 13's :jest:
and specs are as follows, 212-219 .530 .540 lift.
Those lift numbers are on stock 1.5RR's as well. So with the 1.6's i have its .565 and .576
really high lift, not so much duration wise, so it is similiar to a hot cam you 'could' say, its got less duration, but more lift. 113 LSA
AznMuscle
04-29-2009, 06:36 PM
Stop dicking around, and do a fucking 240s cam. You are going to need it.....
greatskiiiier
04-29-2009, 06:57 PM
why dont you both STFU and start modding so you can play with the BIG BOYS
lmao- funny part of that is some guy said the "big boys" part to me when i was trying to get my wheels to stop rubbing (12 bolt swap)
anyways- ditch that cam and give Lloyd Elliot a call (sorry if hes not a sponsor here)- youll def be low 12s if now high 11s then
AznMuscle
04-29-2009, 07:01 PM
I'm having Ed Curtis spec my cam..I got heads sitting in my garage. Trust me, I will be able to run with the teenagers :jest:. Big Boys run 9's....I need my 200 shot and 9 inch first.
greatskiiiier
04-29-2009, 10:05 PM
lmao- i consider Big Boys anything under 15.0, judging by the guy that said it to me lmaoo
AznMuscle
04-30-2009, 12:29 AM
HAHAHAAHAHA! That sucks dude...don't you hate ignorant people?
PNYKLR-TA
04-30-2009, 11:03 AM
HA! ok boss :eyes: i've got a pretty decently high DA to deal with.
And the cam will most likely be changed when i get my new heads, and rebuild. . . but we will just have to see.
OP where'd you go?
